dual climate controls not working. heat/Ac
In my 09 c6 base corvette the heat nor the a/c does not come on when I push the control buttons. Any suggestions in how to resolve the problem.
You probably need a new HVAC head unit in the dash.
You could try to find a mechanic who has a code reader capable of reading HVAC trouble codes, like the dealer's Tech 2. That may or may not be successful.
New head units from a dealer are around $450(ish). Forum vendor Cultrag Performance could probably save you $75+. Or you could shop ebay and such, members here have found units for as little as $150, usually used, so be careful.
Thanks a lot. Is this something that usually goes out? The car only has 26000 miles on it. I took the car to a chevy dealership for a headlight recall and to fix a shift turbine speed sensor. Two days after it being out of the shop I noticed the heat or a/c controls wasn't working.
We are sorry to that you were affected by the recall related to your headlights. However, we are relieved to know that the part has been repaired. If you need assistance contacting the dealership in regards to the A/C and the heat, feel free to send us a private message containing your VIN, current mileage, preferred dealership and full contact information. Thank you, we look forward to your message.
Kind Regards,
Jasmine F
Chevrolet Customer Care
Yes I will check the fuse box but in between time I will make an appointment with the dealership that did the recall work. Do you know what fuse I should check? Thanks for the Help
Under the lid of the fuse box there is a label showing the fuse locations. On my car the HVAC fuse is # 28. Top left corner if your standing next to the passenger fender. Maybe it is loose or not in the correct position or it is bad.
Premium Supporting Vendor
__________________
Phone: 484-334-8833
Owner of CULTRAG Performance
Shop Our Factory GM Parts Website
Phone: 484-334-8833
