C6 stuck in park
C6 stuck in park
05 C6 Automatic sometimes won't shift out of park. I am told it is the shift solenoid in the console. Any thoughts or advice on replacing the solenoid or experience with this problem?
I looked on You Tube for a video on replacing the solenoid but not much luck in finding what I need.
Any help would be appreciated.
Thanks in advance!
Thanks in advance!
Thanks in advance!
Thanks in advance!
Thanks in advance!
Thanks in advance!
http://www.corvetteworldparts.com/20...ck-eliminator/
Received 4,504 Likes
U.S. Air Force
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Thanks in advance!
Thanks in advance!
Now if you are mechanically inclined here is link with pictures you can do to fix the problem permanently so it will never happen again.
Here is post step by step.
Scroll though all the pages, and pay attention to page 3 and 4.
https://www.corvetteforum.com/forums...with-pics.html
If by any chance you have extended warranty still on the car, all you pay is deductible.
Wow what great responses! Thanks to all!
I checked for a recall and there is none.
Read the link to the previous thread addressing this problem and will attempt the wire tie back fix when I get a couple hours.
Will update this thread and let you know how I make out!
THANKS!
THANKS!
THANKS!
THANKS!
HERE is a thread I started a while back when I "fixed" mine.
Your dealer replaced the entire shifter with the same solenoid built into it. The solenoid is not replaceable on its own. That's why its very expensive to fix at the dealer if the warranty is expired.
