Rear Axle Nut Torque
Old 04-23-2015, 10:45 AM
94boosted
94boosted's Avatar
Default Rear Axle Nut Torque
I hate to make a thread just for this but since there is a rule against bumping old threads and I can't find an official Sticky DIY I have to ask. What is the correct torque for the rear axle nut? Specifically for a 2010 GS? I've already bought new axle nuts and blue Loctite but I have no idea as to the proper torque. Some threads show 110ft.lbs, 118ft.lbs, 140ft.lbs, 160ft.lbs..... which is it?
Thank you.
Old 04-23-2015, 11:50 AM
AORoads
AORoads's Avatar
Received 2,481 Likes on 1,944 Posts
St. Jude Donor '15
"In honor of jpee"
I believe the last I saw Paul "talon90" post was 140, but we'll see if that gets any votes. Anyway, that is what I would use. Also, ck to see if it's blue or red Loctite (don't know if it makes a big diff., but I seem to recall it has to set up at least overnite).
here's the page on Loctite. and it cures fully in 24 hrs.
http://us.henkel-adhesives-blog.com/...Threadlockers/
Old 04-23-2015, 01:09 PM
94boosted
94boosted's Avatar
140 sounds reasonable to me.
The TSB here (https://www.corvetteforum.com/forums...-torquing.html) calls for Loctite 272, which isn't even listed on the link you provided. I just assumed that 272 = blue.
Old 04-23-2015, 05:27 PM
John Harry
John Harry's Avatar
St. Jude Donor '10-'11-'12-'13-'14
Loctite 272 is the red stuff.
Old 04-23-2015, 06:07 PM
94boosted
94boosted's Avatar
Good to know, thank you
There didn't appear to be any sort of thread locker on there when I pulled the factory nuts off.
Old 04-23-2015, 07:41 PM
kedar
kedar's Avatar
St. Jude Donor '12
140 with red high temp lock-tite.
Old 04-23-2015, 07:58 PM
Larry Myers
Larry Myers's Avatar
Just bought two of these nuts from the the dealer parts dept
Before leaving I stopped in the shop and asked the Corvette tech about the torque. He pulled the page up. Torque - 151 lb ft.
Old 04-23-2015, 08:15 PM
realcanuk
realcanuk's Avatar
St. Jude Donor '13
Do yourself a favor and after torqueing the new nuts with loktite, use the old ones as lock nuts. Since doing that I never had a problem and like the security of it.
Old 04-23-2015, 08:18 PM
Cherokee Nation
Cherokee Nation's Avatar
In the past it was 160,for reasons that I forgot it has been change to 140..??
Old 04-23-2015, 08:29 PM
RicK T
RicK T's Avatar
Yes, 140 is the latest spec.
Old 04-24-2015, 08:13 AM
el es tu
el es tu's Avatar
screw the loctite... just buy these nordlocks - theyre reusable and you dont have to use new nuts (this is what the zr1 went to).
Old 04-24-2015, 10:16 AM
94boosted
94boosted's Avatar
Thanks all. 140+Red Loctite it is
To Rear Axle Nut Torque
Quick Reply: Rear Axle Nut Torque
