Can you remove the engine from the top side instead of dropping the motor out of the bottom? if so are there any instructions or how to's on doing it. thanks
YES the set of helms manuals{shop} has a great write -up
it can be done without lowering the cradle, did it over the winter on an 06 Z. The steering rack and damper were off to allow more room to pull the motor forward.
