Cam package help
Cam package help
Hey guys im rather new to the ls scene, I'm interested in doing a mild/almost aggressive cam something where I can go about 30k on spring changes what would be recommended for an ls3 car I'm mostly looking for top end power I've seen the ms3 cam and so far it's what I'm leaning towards, my question is what all is needed for a cam swap besides Springs pushrods and lifter trays? Sorry for the super newbie question I would just like to have the proper advice and do it right the first time.
- Spinmonster cam
- Valve springs
- Push rods
- c5r timing chain
- ATI harmonic balancer
- all bolts gaskets and seals
I'll also be putting on Kooks 1 7/8 headers and catted x at the same time
I also did the Comp Trunion upgrade and an ATI balancer.
If the Damper is not pinned, you would want to do that, and many find that the stock damper has issues with wobble eventually, so I will replace mine on my LS2, not sure if LS3 had issues or not
Rockers Trunnions are a good idea on LS2, you might consider them if the Forum search lists issues and the C5R Timing chain, pretty much what the others have said
I'm on the fence for a 233/239 .595"/.603" lift cam swap,
