Rear Hatch Struts - strange issue
So last Friday night, go to put my golf bags in the car for Sat morning t-time in my 2012 GS. Hatch works perfectly. Sat morning drive to the golf course, open the hatch and it falls closed on me. Had to hold it open (hatch is heavier than it looks...), and pull my stuff out. Same to put it all back in when I was through.
Anyone ever had two struts fail simultaneously, overnight? Pretty weird. Have two replacements ordered, should be in this week.
Anyone ever replaced these? I would think it should be simple.
Only one has to fail. The other one isn't strong enough to hold the hatch up on its own. That rear glass is seriously heavy. I've never replaced mine but if they go on the same as the hood struts it's simple.
Save the good one, when you replace the pair, and it will save you buying one next time
You guys were right, turned out only one was bad. It apparently takes both to make it not slam down.
I am keeping the good one for a spare. Easy job, took all of 5 minutes, and most of that was finding something to hold the hatch up while I popped off the struts. Turns out a broken Driver shaft is perfect.
