Harbor Freight Tools bad for Corvettes
Never again will I use Harbor Freight tools on my C6. The only place localy I could find a 1/4 inch pounds torque wrench was there. Now I know why they are only $29. The damn defective tool broke 2 of my intake manifold bolts off in my head. It was only set at 44 inch pounds for the first round. I feel stupid because it was not relized till the second one snaped. Had to remove the intake and fish out the broken bolts. I feel perty lucky that the came out.
Do Not Quench The Spirit
I think harbor Freight is great for "non technical" tools but for something like a torque wrench I would definitely go higher end
My Harbor Freight (Pittsburgh PRO) Torque Wrenches only cost me $9.99. I am an Airframe and Powerplant Mechanic, my torque wrenches must have their calibration certified every 12 calendar months to a standard of 2% Accuracy. The Harbor Freight (Pittsburgh PRO) is only guaranteed at 4%. They have been through Calibration Checks twice from two different Tool Testing Facilities. In both cases they were received in in a 'PASS' Condition, <=2% accuracy, and left the facility in a 'PASS' condition. I have the 1/4", 3/8", and 1/2" drive Torque Wrenches.
I actually used all three today in maintenance tasks. I used the 1/4" and 3/8" Torque Wrenches to install a Stabilator Actuator in a Lear 45. The 1/4" was used at the 109in/lb setting and the 3/8" was used at the 21ft/lb setting. I used the 1/2" Torque Wrench to install the Main Wheel Axle Nut on a Citation Excel (560XL) used at the 50ft/lb and 30ft/lb settings.
I regularly use the 1/4" Torque Wrench for Torque checking the Cell Lugs on NiCad Batteries. 20 cells with 2 lugs each + Pos and Neg terminal lugs to equal 42 'Clicks' per battery cycle, three cycles per battery, and approximately one battery a month.
42X3= 126 Torques per Battery Capacity Check.
126X12=1512 Torques per year. Two years in a row it has been received in in a 'PASS' Condition.
Are you sure you had it set for 44in/lbs and not 144in/lbs?
Edit to Add: I have never seen a Craftsman or Matco Torque Wrench pass a Calibration Certification. I have seen Proto, SK, Mac, Snap-On, KD, and now Harbor Freight Torque (Pittsburgh PRO) wrenches pass.
The Harbor Freight (Pittsburgh PRO) Torque Wrenches look almost exactly like the Proto Torque Wrenches we used when I was in the Army form 1996-2002 as A Black Hawk Helicopter Crew Chief.
I agree, Harbor Freight should only be used for one-time use things. Nothing that requires precision or quality.
I would never let a Harbor Freight Torque Wrench touch an aircraft. Granted you aren't using a ton of in/lb or ft/lb's but still. I don't care if PMEL or Calibration Cell passes it.
It's a shame they don't have a torque wrench that goes to 450 ft/lb's. Would love to use it on our main wheel assembly to see how fast that thing destroys itself.
Received 2,487 Likes
St. Jude Donor '15
"In honor of jpee"
Now THERE is controversy over Pittsburgh PRO....I'm just hoping my Craftsman I use for wheels is "on." It wasn't much money but it wasn't $30 either. I know: cost does not equal quality, nor name either.
Maybe you did not hear/feel the clicks. There is a lot of difference between 44 in lbs and what it would take to snap those bolts. Glad you got it repaired
Received 2,062 Likes
General practice is that torque settings are about 80% of the normal rate when bolting into aluminum. The bolt is rated for 117 lb in dry and GM spec is only 89 with locktite, which initially is considered a lubricant. The 8mm socket should be the first clue for a low torque setting. 89 lb in is so easy that you can do it with your hand choked all the way up to the socket.
The OP should probably be happy the bolt snapped instead of stripping threads in the head.
The lesson here is to check measuring tools for accuracy before using them.
St. Jude Donor '10-'11-'12-'13-'14
I have a Harbor Freight inch-pound torque wrench similar or identical to yours (item #2696) that I use for non-critical things like battery cable nuts, TPMS nuts, etc. It is difficult to feel it click, much more so than other click-type torque wrenches. Before use I actually clamp a bolt in my vise and use the wrench on it a few times to refresh my memory of what the click feels like.
Received 1,867 Likes
St. Jude Donor '15
I have the same torque wrench and used it many times with success over 7+ years. On the very low end settings like you had, the "click"/breakover is VERY faint. It's very possible you just didnt notice it
Case in point I bought a $150 Snap-On 0-200PSI combination inflater/pressure tester. The tool came from Snap-On with certification, but that is not good enough for our FAA Administrators. I send the calibrated tool to our vendor and it passes certification. The day that it comes in I use it to inflate a tire to 162PSI after install. I notice that something isn't right, the pressure test side keeps reading 150PSI three times in a row between burst of Nitrogen, so I stop and put another tire pressure gauge on it. The gauge reads 180PSI. I send out the gauge to the vendor. It is received in in a 'FAILED' Condition. The vendor calls up our Chief Inspector to inform him that the tool is "Out of Calibration" and that all work accomplished with it should be re-inspected. The Chief Inspector tells them: Not a problem all ready done. The vendor continues to inform him that the tool is so far out of calibration that it is B.E.R, Beyond Economical Repair.
We contact the Snap-On dealer that sold the tool to me. He says not a problem I will bring you another one so you can send it out for certification. Same story we send it out, it passes, we put into service. This time I cautiously use the tool to check tire pressure and service a Nose Tire. This time to 125PSI. Same deal like a recording: we send this tool out, It is received in in "FAILED' Condition, re-inspect work, not a problem all ready done, B.E.R, contact Snap-On dealer.
Snap-On dealer says hey I'm really sorry to hear that, by the way we sent the first tool out and it failed Snap-On's test too at the standard 4% accuracy. I will give you another one. Okay, third times a charm right. No exact same thing happens again. Snap-On dealer says sorry that our tool has let you down we will make it up and gives me $300 credit on the truck.
Point is, Snap-On is supposed to be the Creme de la Creme in Professional Tools yet their tools still fail. I have thousands of dollars worth of Snap-On tools in my Snap-On tool box at work.
Professionally I will not buy Mac or Matco tools. I will buy some Craftsman Tools, all SK, KD, Channel Lock, Vice Grip, Deutch, Sioux, Dotco, Chicago Pneumatic, US Air tool, Central Pneumatic (Harbor Freight Air Tools), Makita, Milwaukee, DeWalt, and ACAT.
This is a very true statement, but is not limited to Pittsburgh Pro torque wrenches. At the lower settings on most 'Click Type' torque wrenches the breakaway can be hard to feel. It is also possible with any torque wrench to exceed the torque set. All you have to do is keep turning past the 'click' and breakaway indication.
Received 1,195 Likes
St. Jude Donor '15
I've had fairly good luck with their tools actually. Only have a few things though. Their new "pro" ratchets are actually pretty decent. Also have the blind hole puller and beat the crap out of it getting a pilot bearing out and it did great. Have the 2.5 gallon compressor, and while it's loud/slow, it works and has done fine for about 2 years now
Received 4,511 Likes
U.S. Air Force
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
You'd probably be right for a goodly part of the established automotive group, since most had purchased their tools before HF existed and the younger guys tried to emulate the older ones at work, even though their home tools weren't the same brand or quality.
However, you may be surprised about what tools are used in the millions of other small businesses that also do technical/mechanical work. Craftsman tools (Sears) were only average, but were purchased primarily on the basis of a lifetime warranty from a major retailer. Now HF is the major retailer and the customer still has to decide what tool needs to be bought there and what one from a different source for the job at hand.
The click is very soft on that small of a torque spec and is easy to miss sometimes. I personally only use harbor freight torque wrenches for lugnuts. Everything else i use my craftsman.
If you scan the reviews, that particular Harbor Freight 1/4" torque wrench is very difficult to hear the "click". It actually is more of a release than a click. You may have powered right past the click.
You also want to avoid Craftsman torque wrenches because of poor quality and lack of warranty. At least Harbor Freight will warranty their torque wrenches.
With some research, I found a very good 1/4" torque wrench on Amazon for $38.98.
St. Jude Donor '15
"In honor of jpee"
Vito A., do you recommend the same brand, Tekton, for larger applications such as wheel torque?
I've been using the same harbor freight torque wrench on my race cars and street cars for 5+ years now with out issue.
I'm willing to bet you had it set for 44 ft/lbs.
