C6 Sway Bar Teaser Pics. Coming SOON from RideTech
We have been doing some testing and are nearing Production on the C5 and C6 Ridetech MuscleBar sway bars
front sway bar arm
front sway bar mount
rear sway bar mount
rear sway bar
front sway bar arm
rear sway bar mount
rear sway bar
We have been running the new bars the last couple weeks. They work great. It s nice to be able to change them out quick. Look for the Silver C5 at Bowling Green this weekend!
Former Vendor
For those of you at Super Summit this weekend, the Black RideTech C5Z is running these as well. The MuscleBars are one of the few changes we made on the car this year that have helped me make BIG improvements over last year.
THis looks like a C6 Z06 based on the diff cooler.
Do you have a picture with the exhaust installed?
Thanks!
http://api.viglink.com/api/click?for...e%20Forum&txt=
Thanks!
The part I don't get,
The weak link in the system is not the sway bar, but the end links instead.
So on that note, you can reinvent the wheel all you want with the sway bar, but if your doing this, then redesign the sway bar to work with a better end link system instead (one that will hold up more than a year of hard use and have to be replaced instead).
The big advantages are that its riding on a bearing surface and you get rid of the compliance of the rubber.
It shows oem endlinks on the front bars but you could use anything...
I don't think that I mentioned yet, but these are available for order and should be shipping in the next couple of weeks.
Check them out here:
http://www.ridetech.com/store/muscle...ures_hash=V367
From the Ridetech website:
** Note O.E. mufflers must be modified to work**
