Ls3 FIC1000 Injector O ring help?
Old 05-20-2015, 11:22 PM
GS057
GS057's Avatar
2018 C6 of Year Finalist
Default Ls3 FIC1000 Injector O ring help?
Trying to track down a vacuum leak on my supercharged ls3. I just installed FIC1000 injectors purchased from a member on the CF. I have had an idle issue since the change. Checked all vacuum lines and can not find the leak. The original injectors pulled had RED o rings were they seat in the intake manifold. The FIC injectors have a green o ring were they seat in the intake manifold. Could the green o rings be to small? There are no fuel leaks were they seat.
Thanks, Michael
Old 05-21-2015, 08:38 AM
FICINJECTORS
Supporting Vendor
FICINJECTORS's Avatar
Thanks, Michael
you have the wrong o rings, i responded on the other thread of yours.. call me ill send you the proper o rings.
jon
Old 05-21-2015, 10:44 PM
GS057
GS057's Avatar
Thanks for all the advice. I really apriciate it. The red o rings fixed the vacuum leak. Form the pics you can not tell a big differance in size but there is. Amazing how you overlook the easy fixes when in your head your thinking it is something major.
To Ls3 FIC1000 Injector O ring help?
Quick Reply: Ls3 FIC1000 Injector O ring help?
