MRC Status/Diagnosis?
Is there any method, short of requiring a Tech II (or whatever it's called these days), that can divine whether MRC is actually functional?
I have a 427 convertible; I've never been able to notice any difference in the two settings. Although I am pretty 'sensitive' - I can feel, say, a 5psi difference in tire pressure - I just put this down to a situation beyond my capabilities.
Then I got a CTS-V. It's like night and day, the difference between sport and tour. So I figured, maybe something's wrong with the Corvette.
There's nothing obvious. I'm getting voltage changes at the shock connectors when the mode is switched. I get codes when I unplug a shock. So I have to assume the electronics are functional.
There is absolutely no perceptible difference in behavior. Nothing I am able to do with the car matters (and I autocross it). Not brake dive, not rapid lateral oscillations...nothing. So I've concluded that one of two things must be true:
Is there any diagnostic process that can help with this?
- Something is physically wrong with the shocks themselves - which seems unlikely, since all four would have to be 'bad';
- This particular model is purposefully calibrated in this manner (maybe since it's a droptop). It does ride 'softer' than I expected, softer even than the BRZ I had for a while.
St. Jude Donor '12
You should feel a perceptible difference between the settings if you saw the steering wheel left and right while driving (safely). You don't need high speed to feel the difference. Sport is more responsive. Tour will be much less responsive.
Hence, this thread.
