Low oil level - Do I need to worry?
Just checked the oil level on my GS dry sump and it looks like I was driving around with about half a liter low, anything to worry about? Not a lot of miles during this time.
If you check it the same every time, about 5 minutes after shutting down engine hot, you will get consistent readings. !/2 Liter low isn't a problem. That should be the middle hole on the dipstick. I would top it off some time using the above procedure..
Was it at the full mark when it was filled?
Our wet sump GS uses no oil in 5K miles.
this IS corvette forum where we get ulcers over the torque of a valve cover bolt and 10.000 post's on which torque wrench we used and wheter it's accurate and certifiable to 1 millionth of an inch-pound. a "little more then a pint" I'd get a lawyer and sue under the lemon law and diminished value
You're fine. Just curious did you check it the way described in the manual?
