Cold air intake?
8th Gear
Cold air intake?
I'm thinking on getting an intake and I know there is so many different ones, can someone help me on which would be best for my c6 ls3
Thanks.
Thanks.
Are you looking at CAIs or just different air cleaners? (there is a difference). Specifically, many (most?) aftermarket air cleaners are not CAIs although the manufacturers (and many folks on here) use the terms interchangeably. The stock air filter already outflows the LS3, so you won't see any power improvement unless you go to a true CAI system.
Many folks swear by the Vararam system.
Received 1,673 Likes
I've been looking at Blackwings for mine. I had then on both C5's that I've had.
8th Gear
Yea I'm looking into getting a true CAI
8th Gear
Received 2,060 Likes
If you want the maximum power performance, then Vararam is it. If you want the maximum filtration performance, then the OEM is it. Anything else is a compromise in one direction or the other.
