Stainless Steel Headers Made In USA for Under $800 Shipped @ Hinson Motorsports
Former Vendor
Here you go guys/girls. Notice the cradle bolts were never loosened in the video in order to install these headers. They just slip right up into place.
C6 Header Install, Sound, & Burnout Video.
I'm guessing the "Z06 Edition" headers will fit the C6 Grand Sport w/6spd manual. Correct?
Also, will the Elite Engineering header tunnel plate fit?
The plate is 1/4" thick, and some people have had clearance issues with after market headers, even more so when they add in the thermal overlay pad.
Former Vendor
I just finished installing these. Car sounds great. I was a Guinnea pig so to speak (out of my own pocket of course) i have not had the car tuned yet we litterally just finished the install..
If your looking for a set of brand new headers I can't imagine there being any better value than this. The ceramic coating is what really and truly made me click that buy it now button without hesitation.
I had a couple of issues along the way but Hinson has assured me they will take care of them for me. And it was entirely related to shipping not the product.
Fitment was OK... There was no rubbing and the headers slid right in just like the video. My only complaint was the xpipe slip fit. It's connection was a total bear! Otherwise everything fits perfectly and my tail pipes now line up better than they did with stock parts. Very satisfied.
Sound is great! I've only idled it a couple times to break in the coating but it made my exhaust note come to life. The sound is now deeper and much throatier as a corvette should sound. It added a ton of drone but I think that's to be expected with headers.
Power is yet to be determined but again I can't imagine it making any more or less power than any other set of headers on the market.
Bottom Line:
I would buy these headers again if I sold my car and got another Z06
Bottom Line:
Former Vendor
Bottom Line:
Bottom Line:
The X-pipe is tough to line up. That is the primary reason we suggest using a lift. With the help of a third hand, you can usually get them on pretty quick. We have stopped coating the end of the collector where the X-pipe slides over. The thickness of the coating was making the tolerances tighter here. The X-pipe above this portion is still being coated.
We appreciate the feedback! Heat cycle the coating and get some tuning done. We know that you're going to love the new power.
I understand you can not test every other vendors product with yours. However, can you tell if the clearances would appear to be an issue? 1/4" should not matter unless these are tucked up much higher. On cars that use your heat blanket and your x-pipe what sort of clearance is present?
Thanks for any answers you can provide.
Former Vendor
Curious about this too. The Elite Engineering plate is thicker and there is the option of a heat blanket from them as well. Hinson is listing a heat blanket for the same location as a potential add on to the purchase of this system.
Maybe I missed it in any of the other threads, but what is the inner diameter of the X-pipe for the base C6 vs Z06 versions (or is there even a difference)?
EDIT: Nevermind. Found this post to quote "The "X-Pipe" does not reduce. This is a full 3" system until it makes the connection to the stock axle back, where there on the end it reduces."
So the entire piping is 3" all the way to the axle-back.
The plan is to mate this to the Corsa Z06 Sport axle-back, which is also 3" piping to the exit. No bottlenecks.
Former Vendor
Good to know
#33
When should you guys have a package out for the Grand Sport (2012 m6 Dry Sump)?
Ive read in the post that you plan on having one in a few months but do you have a date set for sure?
Also, how will this set up line up with the corsa exhausts, should there be any complications?
Thanks for the info!
#34
Former Vendor
#35
not happy
i dont know if i got a bad batch, but mine had bad fitment. the x pipe is making contact with the tunnel on the passenger side. it rattles and my 02 also didint fit, i had to cut into the heat shield for my passenger 02 to fit. pretty frustrating
#36
In the process of installing a set right now on an 04 Z16. Primaries fit incredibly easy! Passenger side went in from the top no problem. Driver side probably could have, but I put that one in from the bottom. The slip joints on the X-pipe gave me quite the struggle for awhile! Couldn't get it to go further than halfway on. Pulled it off and used a thin coat of bearing grease and it all slid together extremely nicely after that!
So far, so good...
Edit - just realized this was in the C6 section. Oh well... Lol
So far, so good...
