Base C6 Brake Rotors -different?
Old 07-06-2015, 05:50 PM
jayess71
1st Gear
jayess71's Avatar
Default Base C6 Brake Rotors -different?
I ordered Rear rotors and pads for my Base C6. I received 2 different rear rotors. They look very similar but not exact. The difference seems to be just the lip around the outside of the center hub. I called the supplier and was told that it does come with different part numbers for the right and left. These are not vented or sloted. Why the different part#s.
Old 07-06-2015, 06:18 PM
HBsurfer
HBsurfer's Avatar
Received 1,105 Likes on 706 Posts
i wouldn't worry about part numbers but the rotors should not be different from one side to the other.
Old 07-06-2015, 08:28 PM
HOXXOH
HOXXOH's Avatar
Received 2,058 Likes on 1,503 Posts
Rear rotors for the JL9 brakes (base) are identical side to side. They are vented to draw air from the axle side and are 12" diameter x 1" thick.They do not have internal vanes for directional airflow, but have strategically located connector posts to expel air regardless of the rotational direction.
Old 07-06-2015, 10:29 PM
jrose7004
jrose7004's Avatar
Received 1,672 Likes on 1,295 Posts
Both rear rotors should be the same.
Old 07-09-2015, 03:23 PM
Kent1999
Kent1999's Avatar
Received 1,651 Likes on 825 Posts
If your supplier is saying he has two different PN's, one for each side, I'd be concerned that I had the right parts *at all*, because its not that way from GM.
To Base C6 Brake Rotors -different?
Quick Reply: Base C6 Brake Rotors -different?
