Building LS2 413 Stroker
Custom Brian Tooley Racing Cam 234/244 .602/.605 112LSA +4
LS2 stroked to a 413
4.100 I beam rods
11.5:1 compression
.005 over sized Wiseco Pistons
Steel rings
65cc CNC LS2 ported heads
5 angle valve job
102mm NW throttle body
1 7/8 headers no cats BB bullet exhaust
Monster stage 5 clutch
4.10 gears
Thoughts on what kinda power we should see with this build?? Only debate has been the MSD airforce intake with Nw102 TB being to big for the build...
4.100 I beam rods
11.5:1 compression
Steel rings
5 angle valve job
4.10 gears
GrandpaC6 (10-07-2022)
I'm leaning towards 550-560rwhp...?? Same cam put down 503RWHP and 528RWHP on stock crank LS2... Hoping the 413 will wake it up a little more!
Sounds about right to me. Anything greater would make me question the dyno. My tuner got a big number (that he won't tell) from my LS3 416" strocker and found out that a guy rented his dyno and messed with the setting to show higher number.
Running a bit higher compression at 12.5-13:1, origionally wanted to build the car with the 413 then throw on a twin turbo set up... But that changed so I bumped compression back up... May look at installing alky meth kit to increase longevity
Interesting, didn't know that about Sema, that's actually where I first saw this and decided to run with it... The technology they showed and research in it was A++... I may just have to take it apart and see what production changes they made over that prototype
I am sure that it is a good product, I just don't think that it is as good as the initial claim.
Block is at machine shop still should begin putting it back in car late next week!! Few pending items still, deciding on headgaskets but will wait till after I have block back to measure P2V... And push rods...
Curious to see the gains from the MSD intake over the fast! Will be using the NW102 TB and deciding on SD tune or get larger maf... Since it's staying NA I'll most likely get a larger maf to run with the 102 setup..
I'm more than ready to get everything back in and together!
