air in clutch system.
#41
well finally found the problem and if its not that id be amazed..
There is no pilot bearing on the crank.. Engine builder never put it on and never informed me of it,
hard to tell but here is some pix
prior to removing it first time when motor pulled
Attachment 48366582
Old crank shaft u can see bearing..
Attachment 48366583
and what mine looks like before i installed it back into the car
Attachment 48366584
Attachment 48366582
Attachment 48366583
Attachment 48366584
#43
well removal #2
So far what is broken is slave #2, top disk in the clutch is mangled, not sure about drive shaft have to look up how to remove it from the torque tube..
Attachment 48366552
Attachment 48366553
Attachment 48366554
Attachment 48366555
Attachment 48366556
Attachment 48366557
Attachment 48366558
Attachment 48366559
Attachment 48366552
Attachment 48366553
Attachment 48366554
Attachment 48366555
Attachment 48366556
Attachment 48366557
Attachment 48366558
Attachment 48366559
#48
I'm on my phone so it's too long to scroll back, but I was sure your driveshaft looked damaged the first time. Did you put it all back together with the driveshaft like that? The splines looked terrible. Clutch discs could have spun around with any kind of power.
#49
Did you heat your flywheel to install it? It shouldn't be pulled on with the bolts. You're supposed to heat the flywheel to 200f in the oven or hot plate and quickly settle it on the crank before it cools. Pulling it on with the bolts can result in warping the flywheel. It kind of looks like something is spinning and wobbling. The wear pattern on the slave very odd. Turn that driveshaft (put in neutral) and see if it spinning straight. We need to get to the bottom of this. These parts ain't cheap. Let's try to stop the bleeding.
#50
I do know i Can not get that flywheel off the crankshaft i did some minor prying with a screw driver but it didnt want to budge.. And as you can see no pilot bearing was ever present.. which is why the slave is most likely smoked.. as well as the disk
#51
At this point it looks like the best route (not cheapest) would be to .
1: remove that flywheel and have it checked. If it's good, have it resurfaced. Then new clutch, pressure plate, slave, and that driveshaft needs to be repaired for sure.
I would get a clutch kit that includes the flywheel and slave. My katech zr1 clutch came with flywheel, pressure plate, disc(s), and the slave. Added the remote bleeder for good measure.
I just don't think it's wise to not replace all supporting cast. If you take a chance and have to disassemble the car again, you'll likely burn the car down.
#52
#53
Fair enough, either way, whatever the brand. I think you should start from scratch. things are bent, twisted and out of round. I don't think mcleod would rebuild that clutch disc. if the photo is good, it looks bent. maybe send them some pics and have them tell you before hand. I just don't think I would take that route with my car, and certainly even less with a customers because doing it again for free is from ideal. I doubt 2 slaves in and all that work, you'd like a repeat.
#54
#55
again, doing just the disc might bring more of the same. how can you be sure the pressure plate is ok. if the disc looks the way it does, being squeezed between the flywheel and pressure plate, i wouldn't dare take the chance. if they can do that type of service and properly check the flywheel and pressure plate for out of spec, at the very least get that done.
#58
I had my good used one out and threw it in the garbage. never wanted to risk the chance of selling it and a issue with it arrives and a guy with a similar story to yours calls me saying I owe him $$$.
just be sure you only do this one more time. remember, if you pull that flywheel off (which you should to have it checked) you need 6 new oem flywheel bolts
