1/4 mile MPH
1/4 mile MPH
My 60ft isn't great due to traction and stock tires. My speed at the end of the 1/4 is from 117-119mph. My question is what times would my car be capable of with these trap speeds. I know a lot of variables you have to take into account but just seeing if anyone had an idea. Thanks
Received 2,061 Likes
Actually, I'm pretty impressed with a 1.7 on stock tires, since most people are in the 2.0 or slower range. However, still not in the 11's with that 60', does make me question if the nitrous is working well.
With a 100hp shot of nitrous, traps should be 124+... even if you were hitting it after you got traction.
117mph is pretty much a bone stock C6, I believe...given average density altitude.
Location: Henderson Nv-Rohnert Park/Sonoma C o. ca/born in NY Rockaway Beach.
My car is a 12.4 car with a tune and CAI, only 115mph ... I forget my 60ft
It seems like you may be having issues with the shot.. I would think with the shot you should be doing better than what you are ...
1.7 was a one time best for me. I'm pretty much in 2.0-2.2 60ft. I only have about 25 passes with the car. my nitrous controller is set to engage in 2nd gear and 2500rpm or above and cut out at 6k rpm. By the time I shift into 2nd Im pretty much grabbing 3rd.
I can def tell the difference with the nitrous on or off but my times don't show it that much.
I can run with the nitrous off and make 12.7 - 13.2 passes. I definitely need some good tires but I'm hoping it's just driver error and need for improvement. I also run in competitive driving mode rather than traction control off. My passes seem better with it in competitive driving mode.
[QUOTE=HOXXOH;1590105532]Actually, I'm pretty impressed with a 1.7 on stock tires, since most people are in the 2.0 or slower range. However, still not in the 11's with that 60', does make me question if the nitrous is working well.[/QUOT
Would you assume that if I ran a 2.0 60' that I should still be into the 11's?
[QUOTE=615C6;1590110931]
nope...definitely will not be in the 11s with a 2.0. however...you should be in the 11s with a 1.7 60ft and n2o.
Probably not NA. But probably yes with nitrous.
I ran 1.9's bone stock with a best of 12.41@ 117+. I also ran 1.9's with minimal mods at 11.9's @ 119+ all on street tires. With more mods I managed 11.4's @ 123+ on a 1.75 60' and still on street tires.
That just tells you, that the 60' time is important, but also that after the 60' makes a lot of difference too. The wife's Caddy V6 runs 2.1's, but only 14.9's @ 96. It's a good start and a poor finish.
If you did 12.2 with street tires, I say a smaller lighter 17" drag radial set-up with a 275/40R17 and go there with no more than a 1/4 tank of gas 11 is all yours. pull the passenger seat out if you have to it made a difference for me. think it weighs 53lbs and I'm already 230ish lol
[QUOTE=HOXXOH;1590116042]
Are you M6 or auto? What RPM where you launching at with street tires?
