Are the L92 Chevy valves #12612427 Iconel?
I was talking to a head builder and had asked about these valves while I was getting LS3 heads CNC ported. He told me they are not Inconel. I found several links that say they are. The builder is a reputable shop, but I seem to see conflicting information on these valves and even the weight of the valves. Some have said they are heavier and some say lighter than the standard LS3 exhaust valves. I would love it of some of the knowledgeable folks here have any guidance. I have read that the stock exhaust valves for an LS3 are stainless? Lingenfelter's CSR said that is what they use in their CNC Iconel upgrade.
http://www.summitracing.co/parts/nal-12612427
http://paceperformance.com/i-8146347...ust-valve.html
http://www.lingenfelter.com/mm5/merc...w=&range_high=
I've never heard of Inconel referred to as a 'stainless' alloy. That term is used to reference steel alloys. Inconel is Nickel-based. However they do exhibit great corrosion resistance because of the chromium content, so in that sense it does have the 'stainless-like' characteristic of SS.
Weight comparison could yield confusing results, because some valves are hollow and some are solid.
The LS3/L92 casting heads are the same, but the valvetrain differs I believe. What did you supply him with?
My final thought is that one of these CSRs is wrong, but I will not do this work and spend this money unless I get a stronger valve train.
