New LS7 in my Z06 - Question
Received 1,403 Likes
2017 C7 of the Year Finalist
St. Jude Contributor
A new LS7 was installed into my Z06. Work finished this afternoon. I talked with the technician briefly late this afternoon. I said to him "after its all together, just do a basic "street" alignment." Nothing drastic, I'm not taking this car to the track anymore. I'll return to the track next year with a C7Z06.
He tells me an alignment isn't necessary. How could that be? After removing the engine cradle and everything else that's involved when removing an engine how can the front end of the car not need to be aligned?
It just seems impossible to me.
I WILL get it aligned at Phoenix once the car gets out of the Chevrolet dealership but I'm just shocked that they think an alignment is not needed. Am I missing something here? Or is the Chevrolet tech missing something here.
Interested in what people think about this.
I agree with both of you, and I would have it checked anyway, as you plan to do.
I would also pay very close attention to the oil system, to ensure that the new engine breaks in properly.
Depending on why you had to have it replaced would play into how much attention I gave it.
Meaning, if it was because of an engine failure, hopefully they really flushed out the entire dry sump system thoroughly, etc.
Thank you both. I appreciate your replays.
I will keep an eye on the oil. I'll change it at 500 miles and 2000 for starters.
Received 1,193 Likes
St. Jude Donor '15
Previous responses are correct. Still worth checking, but you'd be surprised how much of the suspension stays together when dropping either front or rear cradles. You can keep all the alignment stuff as-is actually. As long as the cradles go back on in the same place, alignment should remain the same.
Again.. still probably worth checking.
If it hasn't been aligned for a while, and you used to be somewhat hard on it, Id do it anyway.
Think he probably test drove it, felt it was ok, and figured he'd save you money.
Fact is, they dropped the ball a bit. They could have and probably should included the alignment in the estimate. Always better safe than sorry.
