TTop keeps making a cracking noise up front, why? how to correct?
I just completed re greasing and tightening the bolts on my TTop and still I get a cracking noise coming from the top front near the front pillars of my TTop. Are there any suggestions how i can rid myself of this problem or is this just the way the corvette is with no solutions available?
thanks boonie
thanks boonie
I had the dreaded top creaking on my 06, GM replaced every thing including the latches, right after they did that it STILL made noise! as a last try I took dielectric silicone grease and greased EVERYTHING! the seals ALL the way around the latches and latch seats, pin pockets everything that could touch the top{ not worried about saving grease}, and guess what?... not a sound in 8 years! not a sound. GM sells their's as a seal conditioner, it has a part #, but I just used something I got from a electrical supply house or auto parts
Here you go. One of the best How-To's on the board.
I followed the directions, and solved my problem instantly. Absolutely no issues since.
https://www.corvetteforum.com/forums...p-service.html
