RPMs different? 07 TO 13
Old 08-13-2015, 10:02 PM
Rick Washburn
Rick Washburn's Avatar
Default RPMs different? 07 TO 13
I just traded in my 07 stick for a 13 stick I noticed rpms are higher. I know that I went from 6.0 to 6.2 liter but tire height is the same so I'm wondering if the rear end is a taller gear.
Old 08-13-2015, 10:51 PM
ChevyDave
Support Corvetteforum!
ChevyDave's Avatar
well, i know this seems accurate. but it really doesnt explain your rpm change.
Old 08-19-2015, 10:12 AM
Orion2011
Orion2011's Avatar
LS3 cars have a lower rear end ratio than the LS2 cars.
Old 08-19-2015, 02:05 PM
ruxvette
ruxvette's Avatar
Received 3,601 Likes on 2,334 Posts
2016 C6 of Year Finalist
Never heard that before...
Old 08-19-2015, 02:18 PM
ruxvette
ruxvette's Avatar
I could be wrong, but I believe the r/e ratio is the same for both....3.42. I suspect your '07 was a base and the '13 is a GS. The difference is in the 6th gear ratio (per ChevyDave's post): .50 in the base '07 to .57 in the GS. So the engine turns slightly faster at the same speed.
Old 08-19-2015, 02:32 PM
timd38
timd38's Avatar
If you have an 05 automatic.
Old 08-19-2015, 03:00 PM
Kent1999
Kent1999's Avatar
Received 1,651 Likes on 825 Posts
Since both cars were stick -- the rear end ratios are the same.
So either:
Your 07 was a Z51 and your 13 is base model? (rpm's would be lower now)
Your 07 was a non-Z51, and the 13 is a GS? (rpm's would be higher now)
Either would explain a difference, since the trans ratios are different for Z51 option or GS model than they are for base models. Since you say its higher, I'd agree with ruxvette that your 13 is a GS.
Old 08-23-2015, 01:24 PM
Rick@RKT Performance
Supporting Vendor
Rick@RKT Performance's Avatar
St. Jude Donor '08-'09-'10-'11-'12, '14-'15-'16-'17-'18
Your 07 was a base model (or Z06) and your 13 is a Z51 or GS. MM6 compared to MZ6 ratio transmission.
__________________
Old 08-23-2015, 11:58 PM
HOXXOH
HOXXOH's Avatar
Received 2,058 Likes on 1,503 Posts
Not all tires of the same advertised size are the same height, nor are new vs well worn the same size. A 285/35R19 in one brand is as much as .3" difference as another and wear from new at 10/32 to 2/32 used, accounts for .5" in height. So tires of the "same size" can have a 3% variation and show up as 50 RPM difference at a true 70 MPH on the same car and more if the indicated speed is not the true speed. That doesn't even include tire pressure differences, which can change height too.
To RPMs different? 07 TO 13
Quick Reply: RPMs different? 07 TO 13
