Clutch fluid change
2023 C2 of the Year Winner - Unmodified
2020 C8 of the Year Winner - Unmodified
2020 C6 of the Year Winner - Unmodified
2020 C2 of the Year Finalist - Unmodified
2017 C2 of the Year Finalist
2016 C2 of the Year Finalist
Clutch fluid change
Took my 427 to the dealer today to flush the clutch fluid! Got home and it looks as dirty as ever! They said the only way to make it clear is to keep doing the "Ranger" method a dozen times!! Is this the only way to clear the fluid???
Appreciate the advice
Thanks all for the clutch fluid change info. I didn't realize this fluid needs to changed more often but will do this ever year from now on. Easy to change and doesn't take much time. Again appreciate the tip!
Received 1,194 Likes
St. Jude Donor '15
Every year?
This is something people do weekly/monthly. You just use a turkey baster to suck fluid out of the reservoir and fill it back up with fresh fluid. Takes 2 minutes
Without changing it regularly it doesn't really accomplish anything
if you installed a remote bleeder, you can use a vacuum bleeder and keep it crystal clear like mine. I replace mine every time I track or once a month. takes about 3 minutes with this set-up.
1. use vacuum to empty reservoir, then wipe interior with with clean cloth.
2. fill reservoir passed full, apply vacuum to remote bleeder and crack open the bleeder screw.
3. Keeping an eye on the level, never let it empty the reservoir, as it could suck air into the system. I nearly empty it 2x
4. Tighten bleeder, check level and you're done.
Is Castrol dot 4 ok to use?
