BEST tire choice for dig racing? 06 m6
Looking for input on tire choice for dig racing my 2006 manual trans corvette. have a set of 325/40/18 m&h racemasters now and although the car dead hooks, it seems like they are killing me on the big end. I was thinking of switching to a shorter tire, but i'd like to keep my 18" wheels. Any suggestions? I've heard that the mt e/t street 2s are working good.
You are correct, the MT ET Street II is probably your only other decent choice in a 18" DR. MT is about to start shipping the S/S tire which i think is going to replace the ET II.
good luck and let us know what you find
So is a radial actually better for a manual car? Car has a custom cut tick cam, ported fast intake and tb, 1 7/8" headers, full 3" exhaust. not sure on exact power but it made 397 before the cam and intake. I have a centerforce DYAD clutch with tick master as well. At the track i'd like to be able to just dump the clutch from high RPM instead of slipping it.
I run a small diameter, narrow, stiff wall, 15" slick that would benefit a lot of cars if they could get them to fit.
yea, i'm finding hardly anything in a 17" bias ply. my 325/40/18 racemasters have a good bit of sidewall as you can see in the pic, and they hook like a mother but i just think i'd benefit up top from a smaller tire. the car was trapping only 121 the last time i went to the track
I have a hoosier 315-35R17 DR and really like them. Just prdered my 2nd pair. so far cut a best 1.52 60ft, and think once I get the hang of it maybe see a 1.45-1.47 but as rob said i have a forgiving ZR1 clutch.
315's will rub on a regular c6.
You can't dump the clutch in a Vette, the rears won't take very many of those. Bias ply will enable faster release as RobZ says, but you need skinnies up front as well or you will be weaving all over the track at the big end if you mix bias rear and front radials. Plus you can't street drive bias ply, if you hit a puddle you'll be swapping ends.
Shorter tires will help launch ET and MPH. Are you shifting to 4th? You might have to with shorter tires but they will still pick up quite a bit of ET for you.
18 is pretty lean in selection, but I recommend Mickeys. The 305/35/18's are 26.6 tall which is too tall for my taste. I'd prefer 17" rims and 275/40/17 which is 25.5 and the extra inch makes a bit of a difference.
Drag Racing tires
Go to the 1/4 performance chart and see what the top drivers are using.
Find the class that closest fits your car. That should give you a pretty good idea of what to use.
I see more Hoosiers making record passes than any other tire. Check and see for your type car and set up.
Good luck
Good luck
