Brake pads - Z51 vs. non-Z51
Old 10-04-2015, 09:57 PM
Dave S
Retired & lovin' it!
Support Corvetteforum!
Dave S's Avatar
Default Brake pads - Z51 vs. non-Z51
So I've had my '05 Z51 since new & figure it's time to change pads & maybe rotors this winter (just turned 48K miles). Started to check different websites to see what's available; prices; etc. First thing that's confusing me is that there doesn't seem to be separate listings for Z51 pads vs. non-Z51 pads. There are certainly separate listings for Z51 vs. non-Z51 rotors, but not the pads themselves (checked Rock Auto, Auto Anything, Advance Auto, etc). Is it correct that the pads are the same & only the rotors are different?
Old 10-04-2015, 10:24 PM
EVRose
EVRose's Avatar
You wont find "Corvette Z51" listed anywhere because Z51 is not a model. Any brake pad listed for your year will fit since the calipers are the same weather you have Z51 or not.
Old 10-05-2015, 09:02 AM
Dano523
Dano523's Avatar
Received 3,019 Likes on 2,175 Posts
The Z-51 performance option brake pads (J55) are the same size as the base model pads (JL9), but the Z-51 option pads are a great deal more aggressive over the base pads instead. Hence they offer more initial bite and better over all feed back then the base pads instead. Also at the same time, they will dust a lot more, and wear themselves and the rotors out over base pads faster too.
So the J55 HD front pads are gm#19152862 , and the rear J-55 HD pads are GM#89026853
Amazon.com: ACDelco 171-0946 GM Original Equipment Front Disc Brake Pad Kit: Automotive Amazon.com: ACDelco 171-0946 GM Original Equipment Front Disc Brake Pad Kit: Automotive
Amazon.com: ACDelco 171-0964 GM Original Equipment Rear Disc Brake Pad Set with Guide Pins: Automotive Amazon.com: ACDelco 171-0964 GM Original Equipment Rear Disc Brake Pad Set with Guide Pins: Automotive
As for aftermarket HD pads over the OEM J55 pads, this becomes a grey area with heat range intent. The OEM pads have a heat range for both DD and autocross, while some of the after market HD pads to the same grip at the j55 pads, have a lower heat range use instead (will work for DD, but may burn them up if you are auto-crossing instead).
Old 10-05-2015, 11:23 AM
schizcat
schizcat's Avatar
Yup. Do a search for the AC Delco part #'s and look for them on Amazon. Cross check them with some of the aftermarket stuff. Also remember what you will be doing with the car. Road race, track, street, etc.
Old 10-05-2015, 12:00 PM
Adam@Amp'dAutosport.com
Supporting Vendor
Adam@Amp'dAutosport.com's Avatar
St. Jude Donor '11,'13
Yes! If you want a quality aftermarket pad take a look at the Carbotech 1521 pad. low dust stops like OEM if not better and last longer. 100% non corrosive dust will not harm your paint or wheels.
If interested let me know I will be happy to help you.
Carbotech™ Bobcat 1521™ The Carbotech Bobcat 1521™ is our high performance street compound that is our most successful compound. The Bobcat compound is known for its awesome release and modulation, along with unmatched rotor friendliness. Like our AX™ & XP™ line of compounds, Bobcat 1521™ is a Ceramic based friction material offering minimal rotor damage and non-corrosive dust. Bobcat 1521™ offers outstanding performance, even when cold, low dusting and low noise with an excellent initial bite. This compound’s virtually perfect linear torque production provides incredible braking force without ABS intervention. Bobcat 1521™ operating range starts out at ambient and goes up to 900°F. Bobcat 1521™ is suitable for ALL street cars, perfect for your tow vehicle, police cruiser. The Bobcat 1521™ compound has been found to last two-three times longer than OE pads you can purchase at a dealership or national retailer. That’s one of the beauties of Carbotech Ceramic brake compounds. Bobcat 1521™ is NOT recommended for any track use.
F:$148 R:$128 Less 5% forum discount.
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Old 10-05-2015, 10:50 PM
Dave S
Dave S's Avatar
Aha.....perfect answer to my question. I had seen the J55 & JL9 references on some listings but was unsure what they meant....now I know. Thanks....
Old 10-06-2015, 12:06 AM
HOXXOH
HOXXOH's Avatar
Received 2,061 Likes on 1,505 Posts
Back in '04 when the '05's were introduced, the aftermarket suppliers were only aware that the Z51 option included larger rotors along with some other parts and therefore called all non-Z51 optioned cars a "base" model. Most all of them still don't know that the J55 brakes were a stand-alone option, nor do they know that starting in the '07 model year all F55 optioned cars used the same J55 brakes.
When you called your car "my '05 Z51", you made the same assumption, which is why EVRose brought it to your attention. It's also why, you should not refer to rotors as non-Z51 rotors, since about 20% of non Z51 option cars had J55 brakes.
Old 10-06-2015, 02:32 AM
artinist
artinist's Avatar
educational thread. thanks
Old 10-06-2015, 09:25 AM
Cor430vette
Cor430vette's Avatar
Were lucky to have Dano he is always willing to help and provide great information. Thanks Dano...
Old 10-06-2015, 03:55 PM
SC-C6
SC-C6's Avatar
Thx, Dano you have been a great help.
To Brake pads - Z51 vs. non-Z51
Quick Reply: Brake pads - Z51 vs. non-Z51
