Cam help
Cam help
Will be my first cam swap I do to my car and want the best cam that will give the most to my car. It's a 2007 c6 ls2 z51 could say it's my daily so don't want an extremely cam or a cam too choppy. I have some 1 3/4 long tube headers I'll install once I start the cam swap have a k&n intake and will be tuned after cam. What cam should I look into that will fit my motor good which just will be intake,headers, and cam. It's a 6 speed btw. Was told to look into tick performance cam. Any help will be great.
Tolero Apto Victum
OP: I have a mild cam on my 07 A6 DD, which has over 200K miles on it. The specs are in my profile, also you may want to contact this guy, a lot of members like him. http://www.guerragroup.com/#!motorsports/c1y41 also check out http://www.livernoismotorsports.com/...-Corvette-LS2/ Good luck with your mods!
I'll check that out thanks.
Give us a call, we can definitely get you fixed up. Just let one of our guys know what you have in the car, and what you want out of it and we can get you a cam spec'd out no problem. If we need a complete custom cam based on your goals we can handle that too...
