LS7. .. what are the best and most powerful heads available for a ls7
I want to know what are best and most powerful heads available for my 09 Z06 heads. I was thinking Mast black label 305 heads? What do u guys think?
Depends on cam and compression you plan on using which you didn't say.
If stock compression and hydraulic cam I like the Trick flow Gen x 260 ls7 or the Mast 285.
cyber09Z (11-18-2015)
The biggest problem with the LS-7, getting a intake manifold under the hood that is not going to air starve it at max RPM's instead.
So before you do any other mods, figure out how you are going to correctly air feed the mod'd engine to begin with.
Hence even on a Ls-7, the fastest/cheapest way to make power with the stock hood on the car, and to get the engine enough air that is demanding, force feed it pressurized air instead (read super charger).
