Best 2 pc light weight rotor for grand sport...
#41
Actually I can set you up with a less expensive RB option. This is a more economical option created to compete with other lower cost traditional surface mount rotor offers.
http://www.racingbrake.com/ProductDe...oductCode=2148
#42
specs for z06/gs front rotors can be had through wilwoods website on the spec sheets for their direct replacement rotors:
http://www.wilwood.com/BrakeKits/Bra...tion=C-6+-+Z06
14" x 1.25" rotor ring
0.23" offset and 0.3" face thickness rotor hat so 0.53" from the face of the rotor to the face of the wheel/hub
Note: this is all assuming wilwood's specs are correct
As far as "best" - there are too many brands to really go through, but most will be 800 to 1000 bucks. The best ones will have floating retainers rather than bolting the rotor straight to the hat.
Also if you get the brakes custom made, you can spec out titanium for the hats (a couple companies make Ti rotors too but the cost is ridiculous for something that is consumable); this will further help weight and heat transfer to the hubs.
xBoostx (01-05-2016)
#43
Former Vendor
The above parts are the basic 2pc non floating type.
The full floating parts for the Corvette are
As found in the Aero6 race kit with the desired 20mm pads.
#45
#47
Group buy, middle of winter, online retailer...how can I get sweet deal on a full set of your center mounts????
#48
If someone can convince me that the others are equivalent, or superior, then I'd listen.
#49
It also has no functional advantages, I would think it only creates more turbulence at the base of the rotor ring making it more difficult for air to flow through the rotor. My guess is they did it so they only had to make tooling for one rotor instead of having to make left and right hand specific castings.
#50
That radial design is exactly how they build high end motorcycle rotors.
#51
Even if they were cast iron 3000+ lbs. and big wide tires is a far cry from a motorcycle...
#53
You mentioned failures, I'd love to see a link or something as I'd like to get educated on the topic. I realize that I can't go back to the track until I get more brake under me so after my car gets back from Dedicated motorsports for some engine work, brakes will be on the list shortly.
#54
Oh I know, well aware which is unfortunate but hey that's the world we live in. I guess my point is that with something like brakes when there are a couple options that are 100% American made for the same price it would seem like a no brainier.
#55
The cheap ones are made of SS. The race rotors are cast steel which I why they rust so much. SS doesn't dissipate the heat well.
Just do a quick google image search, this link popped up for me right away with a few examples, scroll to the bottom.
http://www.audizine.com/forum/showth...3#post11129413
I'm sure they've sold a lot of these and most work just fine but it's an inherently bad design so it's not surprising to see it cause issues.
#56
The radial mount is a horrible design, any engineer knows that cast iron is not meant to be put in shear like that. Just do a little research, there's a number of those that have failed...
Thanks again.
I have a little time to think about it. I don't fully understand the differences with the Zips, Colemans, Giros, etc...
#57
Platinum Supporting Vendor
#58
Thanks for the heads up. After reading around a bit online, it's clear the Racing Brakes have has some breakage likely due to their radial design and that's not a risk I'm willing to take.
Thanks again.
Thanks again.
#59
Coleman does not make two piece rotors for the Corvette. They make brake rotor disks and then custom machine them for their customers (Zip). They do not make the hats and they do not share the deminsion that they machine the rotors for us. Coleman is simply the manufacture of the rotor disk.
Thanks.
68LS2Camaro (01-31-2018)
#60
What direction is the shear on the bracket are you looking at???? Have you seen the size of the brackets, if you look at any real race car they have radial mount calipers on them. I would never run a caliper that ears on it in a race car, the radial mount is much stronger.
