P0341 code after cam swap, need help
Old 12-28-2015, 11:19 AM
Robg91z
Robg91z's Avatar
Default P0341 code after cam swap, need help
He guys did a cam swap on my 13 ls3 , noticed extended cranking. Performed the dyno tune and car ran real good. But tuner checked and found code p0341 camshaft position sensor. After that recently replaced the sensor and still doing the same problem. On a side note to give you all a bit more info, i did the 3 bolt conversion on the cam sprocket. So please put your input, car is getting kind of annoying just cranking for a while. Thanks
Old 12-30-2015, 03:56 AM
sevinn
Support Corvetteforum!
sevinn's Avatar
St. Jude Donor '14, '16
Did you put in a 4 pole or 1 pole timing gear? Is the cam position sensor hooked up? It's on the timing cover. You should be able to reach it without taking too much apart.
Old 12-30-2015, 01:55 PM
irok
irok's Avatar
Default crank relearn?
did you do a crank relearn procedure after completing the job?have had same issue a few times.the factory service manual says this should be done after a cam replacement.
Old 12-30-2015, 09:55 PM
rpmextra
rpmextra's Avatar
how does it run?
To P0341 code after cam swap, need help
Quick Reply: P0341 code after cam swap, need help
