Want a lil more power. Need advice.
Hi all. I'm 100% sure that a lot of you did the same as I want to, so I really need your advice.
Starting point: 2008 C6 base, auto, LS3, MP112 Maggie with stock 3.4" pulley (7.25 psi peak), Callaway CAI, Bassani catback. All of that is making really good power but I need a bit more I'm not crazy about 1000+ hp race cars, 600 at wheels I guess is enough for me.
So here is the list what I want to do:
1. LS7 OBX long tubes with fast flow cats, 1 7/8, already on a shelf.
2. 3" pulley for Maggie (? what psi can I expect going from 3.4" (7.25psi) to 3.0"? Target is 10 psi, unfortunately Maggie is hot )
3. LS9 camshaft (Or maybe somebody have experience with another mild supercharger cams? LSX? Want a little lope if possible)
4. 3 bolt kit for cam swap - 3 bolt timing sprocket, C5R heavy duty chain (what else do I need? Any gaskets?)
5. Tune (unfortunately I'm too far away from US and e-mail tune is my option. Please advice me good tuner to work with. Heard alot good words about Chuck CoW)
Generally that is it. Guys I need your opinion and advice.
Vasiliy
Vasiliy
Heck if it hasn't been tuned that might be enough.
You are thinking of things in the right order, I'd maybe do the pulley first (cheapest I assume). Also consider a COMP LSR FI grind, and for sure the tune when you are "done" my .02
DirtyOilMan (01-06-2016)
Former Vendor
St. Jude Donor '07-'08-'09-'10-'12-'13-'14
Call me....
Vasiliy
Vasiliy
and I've got a $99. option that will absolutely be MORE FUN than any of the things you've
mentioned.
914-332-0049
Chuck CoW
Former Vendor
Good talking with you today....
Vasiliy
Vasiliy
Vasiliy,
Here are the links I spoke about on the phone....
CoW BOOSTER!
AutoCal
CONTACT US
Call any time.
Chuck CoW
600 at the wheels, through an A6, is a pretty tall order when you're dealing with an MP112. Do the 3" pulley, cam, and long tubes. Enjoy what it gives you. It won't be 600 wheel, but it will be a load of fun on the street and a VERY nice upgrade in power vs what you have now. With a good tensioner and the correct belt, you won't have to deal with belt slip. IAT's shouldn't be a big issue either as your boost shouldn't be much over what it is now. The cam and headers will lower the boost. The smaller pulley will bring it back up. Probably 8.5ish psi when you're done.
Ditch the LS9 cam idea. Nothing wrong with it but you won't even notice it. Runs smooth as stock. Something like a 220/234 118+2 cam would work well. A little lope, but not too difficult to tune. If you wanted more cam music, you could have the same specs ground on a 116lsa with no advance. That one would have a little more chop to it.
Vasiliy,
CoW BOOSTER!
AutoCal
CONTACT US
Call any time.
Chuck CoW
CoW BOOSTER!
AutoCal
CONTACT US
Call any time.
Chuck CoW
As per our discussion in my case I need EFILive Flash that is pretty expensive instead of HPTuner that I already have. I'm not able to send you a PCM. So if you have a chance to adjust my tune with HPTuner software it would be awesome.
Another question is about camshaft. I am absolutely new to this and never had any experience with cams. Tried to find cam with figures you wrote and had no luck. Btw I've read that lift should be not more than 0.600 to keep stock head internals. Is this right? Also I want to keep stock torque converter. Maybe you have some links that can help me?
Thanks and really appreciate your help
600 at the wheels (675 on the motor) is doable with just changing the S/C pulley, but you need to add in a Meth kit as well.
Note, need to check your injector sizes, and even your fuel pump for the added demand they will need to supply.
The meth kit is going to be your safety margin for octane rating/cooling, so the timing can be pushed with the added boost in the re-tune.
For 700hp at the motor, then headers added with high flow cats so the exhaust/heads can scavenge better to hit the higher number.
As for cam, the higher the lift, the faster your going to wear out valve springs, and the more often they will need to be changed. So cam not needed to hit 700HP, just smaller pulley, Meth kit, and headers with high flow cats.
As for Meth mix (50 percent meth-50 percent distilled water), if you check around, should be able to buy 100% methanol from a chemical supply store for under 150 ruble per litter (so the meth mix fluid is kept on the cheap side of under 200 ruble a liter, instead of buying store pre mix that will run you around 800 ruble a liter isntead).
As for meth mix usage, 6 litters should hold you off for a month of normal street driving. and since the mix is just a higher meth content than windshield wiper fluid (wiper fluid has around 20% meth-80% water), you can keep a extra gallon of mix in the back if you run low and need to fill back up on the road.
Former Vendor
What I was advising is the EfiLive AutoCal that is only $350. That is all you need.
Once you e-mail your HP TUNER tunes to me, I'll be able to tell the best way to go.
EfiLive is much easier for me to do remote tunes with, but I may be able to help you with HPT.
Just so everyone reading knows, This customer is in Russia. Just a bit more complicated on the
mail order tune side of things.
Send that e-mail and I'll have a look.
CHUCK CoW's E-MAIL - CLICK HERE
Thank you.
Chuck CoW
Former Vendor
Remember....
You are in Russia and it might not be soo easy to rebuild or get a replacement transmission.
Again, let's look over the overall tune you have before we upgrade the car..
I suspect you have a Maggie "starter tune" and there might be much more on the table.
Chuck CoW
Remember.... The A6 transmission will not like power levels in that area.
Chuck CoW
Chuck CoW
Check e-mail please.
Methanol has a better cooling effect over ethanol, while ethanol has a higher octane rating than methanol.
So if push comes to shove, then run windshield washer fluid that has about 20% meth/80% water (blue winter blend windshield washer fluid), then bump it with 30% ethanol to bring it up to a 20% meth/30% ethanol/50% water mix for the mix to have the car tuned to, and to run on.
If all you can find is summer windshield washer fluid, then figure that its about 16% meth isntead, and go with more 34% ethanol so your only running about 50% water in the mix.
As for 100% Ethanol or Methanol, it not what you want for the TVS-2300, since with it spooling faster and we need water as well in the mix to keep the S/C from just becoming a heat pump instead.
Plus the water in the mix give you more powder, since at it burns, it expands into the steam, which not only give you more push on the down stroke, but keeps the cylinder and exhaust steam cleaned as well. Hence less oil on the piston/ in the cylinders from the steam cleaning effect of the meth kit with water, the less octane loss effect from oil in the combustion chamber as well.
You will want the -20 washer fluid. Most washer fluids rated between -20 and -35 degree's below zero contain between 30-40% methanol. You can then "spike" it with heat (12 oz of pure meth) yay
Or order boost juice from local speed shop or order direct.
http://www.alcoholinjectionsystems.c...icle_info.html
Hence a little higher octane rating on the added alcohol, is much safer, than not enough for the timing advance safety margin, and even with a slight less amount of water, still enough to prevent heat soak.
Former Vendor
Checked out your e-mail.... Check yours...
I do understand that. That is why I wrote that I'm not crazy about thousands of horses. Stock 6L80E has safe limit at 650-670 crank hp according to the info gathered from this forum. So it is exactly around my target 600 whp. And thats enough for me... I hope... My wife hopes when counting family budget
It looks like its very boring to drive and I'm concerned about the trans.
Trans is totally stock and the engine is nothing special.
There's LOTS of room to play not even getting into other mods and such....
Call when you have time.
Chuck CoW
Checked out your e-mail.... Check yours... Logs do not show wide band from what I see.
Chuck CoW
Chuck CoW
Chuck CoW (01-06-2016)
Originally Posted by Steve Haefner
I figured, so basically no tune. He will be happy then
And the log of this best run
Really confused. Probably I can safe my money, stay with headers only plus proper tune and be happy?..
Former Vendor
YES, you can.
I bet on safe Maggie tune. To tell the truth I'm running 4.64 sec 0-60 and 12.61 sec 1/4mi on 305/30-19 Michelin PS, usual road and 68F outside. Forum says that stock cars show these numbers
Attachment 47944409
Attachment 47944408
Attachment 47944410
Attachment 47944409
Attachment 47944408
Attachment 47944410
You can easily go to the next level my way for hardly any money and NO RISK to the car.
Long after that, when you become bored again, then make the other "power" mods.
Having a blower with a STOCK transmission tune does not make you much faster than a stock car.
You're seeing that right now with your photos.
MORE POWER is always nice, but too many people think that MORE POWER is always the answer.
I seem many, many cars that have big mods like blowers that are running nowhere near their potential...
Just like your car.
FOR SURE that's why you're disappointed..... I can fix that easily and inexpensively.
Let me know when you're ready.
Chuck CoW
