Nasty Cam/Torque Converter
Check his thread. Dyno numbers in his sig.
Yes a big cam will buck even with a converter. My friend had a huge cam in his a6 car with a 3200 stall that about shook my teeth out. Theofel. He took it out and put in a smaller cam. Slowed down a little but the car was a lot more pleasant to drive. PM him if you'd like to hear more.
Smart move. The car will be amazing with the converter.
Hoxxoh and Theofel both turned 10's with just converter and headers and tune. It's a great mod.
Proud Owner (01-19-2016)
By chance do you know what Converter they used? And I would imagine that after installing a converter tune is needed or no? I am tuned at moment with HP.
Yes you need a transmission tune for the converter. And you can ruin your transmission very easily with the wrong tune. Be sure and use someone well experienced in tuning the A6 transmission for your work.
I think 3900 got them the 10 second slip. Might have been 3600. I've asked Theofel to step in and report what he used.
Tuners DO NOT lock tunes any more. That was so "2001".
Demand he unlock your tune and then, consider going to another tuner. Blaming a tranny problem on your desire for firm shifts smells like to me.
Good tuners can unlock your tune as well I believe if this guy gives you a hard time. I seem to recall chuck COW stating that he can do it.
If you have HP Tuners try to load the tune and see what it says. I've never seen a locked tune so I don't know. Normally HP will download a tune then ask if you want to license it, you say no thanks, then you can look at the tune to your heart's content, just can't change it and reflash it.
Call LG and see what they can do for you. I've purchased only a cam from them but their customer service has been exemplary and I've seen them help many people on this board over the years.
I will search for their #. Joe you seem to know some stuff. When can I drop off car for install?
I've been a shade tree guy for 35 years. I do NOT know, currently, how to tune an A6 but I know enough to know it's imperative to get someone who does. LG fits that bill.
Stick around this forum, ask questions and keep being kind to others so they respond to you. Virtually anything you need to know about a Vette is here, either search for your question or just ask it, and you will get your answer.
#33
Here you go. https://www.lgmotorsports.com
#34
Former Vendor
St. Jude Donor '07-'08-'09-'10-'12-'13-'14
Thank you Joe....
Thank you Joe.
YES, I can unlock just about any Tuner's engine tune. Also, I've had very good luck "UN-BRICKING"
E38s where the tuner flashed the wrong year OS into it and it crashed the ECM... It takes a while
but I can usually do it. I suppose I could unlock a TCM in principal, but I have not tried it.
I would need to have any ECM or TCM here on the bench a few days to do it.
On the locking topic.... I do understand why people do it. Back in the day there were not many tuners
out there.... Less potential for someone to mess with your work. Not really stealing your secrets, like
people like to think.... But, being responsible for the tune....Just so long as nobody else messes with it.
Times are different now.... EVERYONE is tuning it seems... Most do not have the knowledge or experience
to do it right, and more people are going to suffer than ever before.
Tuners that lock their tunes are obviously looking to limit liability rather than protect intellectual property.
Some people never learn. They run from tuner to tuner and never get anywhere...
Smells like BS to me too.
Chuck CoW
#35
Don't go to a large cam with the A6. My ride ran a 10.6...10.7 with a 230/234 on a 114+2 ( Spinmonster spec) with a a3600 stall. Same set up with an A&A ran a flat 10. If you go to a larger cam or a cam on a 112 you'll get a lot of surging on a A6 tranny and you will loose a lot of driveability. Bigger is not always better. Good luck with you decision.
#36
Don't go to a large cam with the A6. My ride ran a 10.6...10.7 with a 230/234 on a 114+2 ( Spinmonster spec) with a a3600 stall. Same set up with an A&A ran a flat 10. If you go to a larger cam or a cam on a 112 you'll get a lot of surging and you will loose a lot of driveability. Bigger is not always better. Good luck with you decision.
#37
Big cam here on a stock stall...........shakes, rattles and rolls..........just the way I want it!
http://vid1097.photobucket.com/album...pssym6m6qi.mp4
Tip: Don't take your foot off the brake at a red light.
#38
#39
Comp Cams 227/243 .611/.624 113+2 with all supporting mods except heads. The LS3 heads flow extremely well so I did not replace/port them. I've bought a BIGGER cam (23* overlap) that I plan to install when it warms up; and I plan to add the GM CNC heads also. I wrench it all myself, including a custom exhaust that turns down in front of the rear trans axle. I'll try t upload a new video soon.
I can't vouch for LG as I've had negative encounters with them. I will say this: Do not buy the Street Series setup, it fits like crap. :-(
#40
