Thru a Cranfshaft Position Sensor code at the track last night..
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19-'20-'21-'22-'23-'24
I was in the staging lanes last night at the track and went to pull up in line and car almost didn't start and once it did ran pretty rough. Check engine light was on, tach, tire pressure sensors quit working and traction control system went berserk. I couldn't get to my laptop to get it fired up to see what was going on using HP Tuner so I got out of line and went back to the pits.
Pulled the codes and it showed several misfire codes plus the CPS code. I cleared them and shut car off. Started car back up and everything went to working again and engine cleared up. Decided to call it a night since I had a 1hr and 20 minute drive home. Car ran great going home and drove it today without a problem.
I've run the same blower, cam, converter basically same tune for 3 years without any problems with engine codes. Could this just happen to be a fluke one time deal ? Had the battery tested today just to eliminate a possible voltage problem and its fine.
Just seeing if anyone else had a problem similar to this one..
maybe
Supporting Vendor
I've had issues with very slow starting a few times over the years (bad starter, weak battery, engine issues etc) and quite frequently when the car doesn't start as expected, the PCM will throw a CPS code which is misleading because in every case there was never actually anything wrong with the sensor itself.
If you had trouble starting the car, the CPS code is a symptom of the underlying issue rather than the cause.
