replace coolant crossover when doing heads?
Just as the title reads..
Whats the consensus of replacing the coolant crossover i.e. steam vent setup when re-doing heads?
I know there is an o-ring in the ends that you can replace, but supposedly pain in the *** to replace.
A new crossover assembly is like 40 bucks so not expensive in the grand scheme.
If I dont replace it and it leaks, it "appears" easy to replace after the fact or is this not really true?
rjacobs (02-09-2016)
No reason to touch it unless it leaks.
SteveDoten (02-10-2016)
Supporting Vendor
SteveDoten (02-11-2016)
