3 - 4 AMP draw with car off
Old 02-12-2016, 02:09 PM
Nate_M
Nate_M's Avatar
Default 3 - 4 AMP draw with car off
Couldn't figure out for the life of me why my battery was dying until it dawned on me to check for draw when the car was off. Sure enough, I'm getting one HELL of a draw, bouncing around between 3 - 4 AMPS.
Before I start pulling fuses, has anybody heard of this being a problem on the a C6 before and are there any things I should check first?
Thanks!
UPDATE: One of the posts you guys suggested showed a guy that left his multi-meter on for a few minutes and eventually it settled down to normal 4-5 milliamp draw. So, I tried it and it worked! Must be just the startup systems checking for whatever. Anywho, seems to be right now, so now that I have a new battery I'm gonna throw the trickle charger back on it and see what happens.
Thanks for the helps guys!
Old 02-12-2016, 03:50 PM
Seadawg
Seadawg's Avatar
yep, see it happen out here before. Most times it happens right after a battery replacement, or when something acts up with the XM radio or OnStar.
Here is a thread that talks about it, and has other links in it too: https://www.corvetteforum.com/forums...-when-off.html
Nate_M (02-12-2016)
Old 02-12-2016, 05:30 PM
RicK T
RicK T's Avatar
Here is a long, good discussion with some really good info (best on last 2 pages):
https://www.corvetteforum.com/forums...-syndrome.html
Old 02-12-2016, 05:40 PM
Kent1999
Kent1999's Avatar
Received 1,651 Likes on 825 Posts
Any recent changes to the car? (new aftermarket radio, new alarm, new mild-to-wild, etc)
Old 02-12-2016, 08:16 PM
Nate_M
Nate_M's Avatar
Update in first post. Cheers!
Old 02-12-2016, 10:19 PM
AORoads
AORoads's Avatar
Received 2,477 Likes on 1,940 Posts
St. Jude Donor '15
"In honor of jpee"
hope it's a "maintainer" and not a trickle charger.
Old 02-12-2016, 10:22 PM
Nate_M
Nate_M's Avatar
Yep, just a general term. It's the Black & Decker BM3B.
Old 02-13-2016, 08:28 AM
WW7
WW7's Avatar
I can't believe the C6s only have a parasitic drain of 4 ma...My C4 has a drain of 30 ma and this is considered a low normal..With such a low drain why do C6s have such a problem with low voltage batterys all the time?...WW
Old 02-13-2016, 08:44 AM
Nate_M
Nate_M's Avatar
That's my fault. I had my mm in 10AMP circuit, so it only went down to 1/100th amp. So when I was readying .03 - .05, that was actually .03 amps. I.E. probably just North of your 30 ma. Sorry about that!
Old 02-13-2016, 08:53 AM
WW7
WW7's Avatar
...WW
To 3 - 4 AMP draw with car off
Quick Reply: 3 - 4 AMP draw with car off
