Sparco Race Seat and Mounting Hardware Package
#41
NC Events Coordinator
Both brackets have some adjustability no sliding. The Flat black setup keeps you lower the the floor if your taller. How tall are you?
For the driver I would recommend the flat aluminium bracket passenger go with the standard Planted/side mounts. Do you have harnesses or are you putting them in. If so i'd also get the lap belt bar.
#42
Former Vendor
St. Jude Donor '13
Trying to fit a slider in for drivers over 5"11 we have seen issues with head clearence at the roof line with a helmet on. To put the slider in you need the floor bracket, slider and side mounts whole assembly ends up being taller than the factory mounting assembly and really limits head clearence for taller drivers. Even with the slider you can not recline the seat to make up head room as many of the taller drivers do now by laying the seat way back won't work with a fixed mount seat.
#51
I have another brand of seats that the previous owner installed on the OEM gears and motors.
I can't deal with dash lights and I 100% have to keep my seat heater mechanism. But the motorized seat I don't need or want. And I need my seat to be notably lower. Like an inch lower.
Can I just unplug the seat motors and use your seat mounting kit and will I get any dash lights?
What is your return policy on your mounting bracket kit if it doesn't work for me?
Thanks.
Thanks.
#52
Former Vendor
St. Jude Donor '13
Thanks.
Thanks.
