Did I do somthing wrong when I installed my sway bars
I tighten mine to exactly 50ft/lbs. When I put the car in the air tomorrow to check DJ's thought I will reinstall them at 60ft/lbs. Maybe between the two it will be fixed.
Just wanted to give an update.
Just took the car out for a hard drive on a bumpy twisty road.
No NOISE!!!! Cornered like it was on rails!
So here is what I had to do;
I had one washer on the front bushing bracket, I thought the bar moved free enough. It didn't. Add one more washer and the adjusted the end links out 1/8 of an inch.
On the rear I had no washers, just like the front I thought it moved free enough but I was wrong. Added one washer and adjusted the end links almost a 1/4 inch out.
Want to say thank you for all the input. I'm a happy guy again!
DJ
