z06 with a ls3 swap?
i know that sounds crazy but is it possible to swap a ls3 into a c6z? i know i will loose the dry sump but is there any other differences that il have to consider. my ls7 let go and i need to get her back on the road and a small cam ls3 with a blower will make more power than my ls7 for a fraction of the cost. i know this will kill the value of the car but i bought it to have fun with so that dosent bother me to much. all input and opinions are appreciated.
Received 2,060 Likes
If you find a used LS3 from a GS manual coupe, it already has the dry sump.
i already have a new vengance racing cam on the shelf and have a vararam, but id want to go boosted for sure. a dry sump ls3 may cost as much as a ls7 honestly lol
Supporting Vendor
Supporting Vendor
If you dropped a valve then you'd likely need a replacement head. If the cylinder wall is completely destroyed and/or there's a hole in the block then you'd need a new one which cost less than $3000. If the cylinder sleeve is just cracked then it can be resleeved for less than $500. If one of the pistons and/or rods is damaged then that'd run you around $200 for a used replacement.
I've blown a few LS7 engines over time ranging from moderate to severe, so I can probably give you a good idea of your most cost effective plan to get up and running again.
Also, even if you could potentially save a few bucks going with an LS3 I think the financial hit you'd likely take if you ever decided to sell the car would greatly exceed that amount and you'd end up regretting it.
i plan on pullingthe valve covers and busting out a bore scope this weekend. honestly right now i dont have the funds to fix it so im in no rust to tear it down and have parts scattered throughout my shop and the car holding up a lift.
if i can make it to tax time next year id like to buy a forged lsx setup that i dont have to be scared to drive around 800hp... honestly every time i hit the gas with the ls7 i just waited to hear it pop. it may be something simple but i always plan for the worst. i was cruising at 40 and pushed the clutch in to shift to fifth when i heard a hand full of marbles and the motor shut off. pressing in the starter button just makes the starter hit but wont turn it over at all. it is strange there was absolutely no smoke or anything else...
Supporting Vendor
That's how I feel about the ls7. Absolutely an amazing engine. And must be awesome to have that raw power and the high pitch sound it makes an ls3 doesn't have.
But my days of worrying are done. I'm biased so yeah if you can score the ls3 with blower cheaper for your z, do it. It'll be unique.
Once my factory warranty expires in December, I'm putting a blower on my GS.
ey bad that marble description not too good but it could be a whole lot less than you think though just pull the spark plugs off to find out which side then pull that head the worth it could be is a cylinder sleeve rod not so much often the crank survives, is hard to kill a head even with severe marks they just clean up with a porting bit new valve and back for more.
If no coolant in oil likely sleeves good light scratch or two in a sleeve don't do crap ether let em rip but don't let a z just seat there.
