What Harmonic Balancer for a 2005 LS2?
Gents,
I need a new harmonic balancer for the vette. It started chirping at 1500 rpm and I have a major wobble.
I do not plan to make changes to the car increase the RPM range. I am looking at balancers and they range from $150 to $400 with ATI being the most expensive.
I also do not want underdrive or over drive.
What is my best option and do we have good vendors with good prices here to buy from?
I know I also need a gasket, ARP bolt and a few other items.
Thank you!
Notes: Maybe the ATI ATI-917246 ?
Thank you!
I have the Powerbond on my car, get APR bolt and plan a whole day to swap it. Not hard but steering rack is a pain in the butt! I actually managed to swap one with out steering rack removal! Loosen 2 front engine mount bolts, lift the engine ever so slightly enough to swap it and lay the engine back down on bolts.
ATI and be done with it.
Same with the ARP bolt, does anyone have the part numbers to what is needed?
Part number for ATI balancer is ATI-917246 and part number for the ARP bolt is ARP-234-2503.
ez2spd (05-22-2016)
Now very confused.
Why not the just slightly smaller and lighter 917266 at 7.48" compared to the 7.53"
http://www.atiracing.com/products/da...ts/damserp.htm
ez2spd (05-23-2016)
I havent replaced mine yet. But, there were a few threads a while back that said to go with the stock equivalent. I believe its the steel balancer. The other is meant for race applications...like true race cars. From your other posts, you wont be trying to push a stroker through your car.
Thanks for the advise. This winter the car will have a cam change, headers and fast intake this winter. Just need to get it running for the summer. That way my friends can go to shows with me and have something to drive.
ATI said either will work and the aluminum one will last on the street no issue. They also said the weight was of very little significance and would be a few hundredths of a second on the track.
Due to NEVER wanting to do this again and not caring about that little time, I went all steel for longevity.
Summit has the ATI Pulley, ARP bolt and the GM Performance Parts Seal.
ARP-234-2503 BALANCER BOLT KIT
$34.57
Summit Racing Equipment ATI-917246 DAMPER - 7.5 - ST LW - 6 SERP
$444.97
NAL-12585673 CRANK SEAL
$17.97
NAL-12633904 FRONT GASKET
$18.97
Last part is a timing chain gasket, just in case. NAL is GM Performance Parts
$34.57
$444.97
$17.97
$18.97
Received 1,193 Likes
St. Jude Donor '15
Running Summit C2501 on mine for a while now, no issues. ATI makes a nice part though, no doubt about that.
I have the Power bond SFI unit, runs nice, car got "smoother" after install, save over $200 compared to the ATI. you could put in a new Melling oil pump M295 $60.00 and a C5R timing chain while your there. with the savings
Naturally Vain (02-23-2019)
C7-Daddy (05-30-2016)
I installed the Powerbond HB on my 2005 this week. No need to pull the timing cover as you can easily replace the front seal with the cover in place.
https://www.corvetteforum.com/forums...-balancer.html
Roy
Roy
Roy
Roy
I am satisfied with Powerbond.
