Power steering overflowing!
Had a track day at Limerock this past weekend. This was my first one taking my vette and the power steering reservoir was overflowing badly during each session. I have not noticed much of a difference in steering feel possibly a little tighter. Is this normal? is there a way to prevent this from happening in the future?
Any info appreciated!
sounds like you may have had it over full, you do know that their supposed to be checked hot and it's lower in the tank then one might think, that being said after the first overflow it should have found it own level. may have to unhook the return line and check for flow, can't really think what could cause that except for being seriously over full?
I am with post # 2.
Over filled.
What would cause an over flow?
Oil boiling over from heat, air bubbles, incorrect viscosity, clogged line come to my mind.
So, clear 'er up, refill to proper level with proper oil and monitor.
Let us know.
Over filled.
Let us know.
Received 1,194 Likes
St. Jude Donor '15
Overfilled. Mine use to do that too when I had it filled to the "full" mark on the stick. Suck some out with a turkey baster.
Agree...not too much else it could be.
Heat is your problem, expands and boils over. Install a PS cooler or as post above suggested install Turn One PS pump made for track use. Extended periods of high rpm's heat the fluid.
Like they say above if you don't have a PS cooler you need one. The factory pump will boil that stuff at high RPM. I take my 87 IROC to Lime rock and i had to add a cooler AND a turn 1 ps pump. Now i don't have anymore trouble.
The cooler is making a lot of sense. If you're topped off and the fluid reached a super hot temp, it expands A LOT!. This is evidenced in modern automatic transmissions today where the fluid levels are set using a temperature probe through the fill port. As the fluid temp heats up it expands and runs out. At a certain temp you cap off, but as the temp continues to rise the fluid continues to expand.
I think this one is solved.
Received 2,051 Likes
St. Jude Donor '13
I didn't notice any mention of the fact that the little dipstick has two markings- "Full Hot" and "Full Cold", or something like that.
Even keeping it at the proper level, mine (Z51) will splash a little fluid around the cap if I get it hot and run it hard.
Even if he does it may not be enough in all situations. My 02 C5Z came with an oem PS cooler but 20-25 minute track sessions varying rpm's between 2500 - 7000 can cause fluid to boil over quite easily in summer temps. I added a Setrab cooler in series with my oem cooler...problem solved.
Setrab really builds nice coolers. What did you do for lines? I bought busted OE cooler and was trying to use the lines off of it as a template, but lost interest in the project about a year ago, and never finished it.
I was thinking of doing the same, just because the OE does not look very robust. I have a Setrab one on my diff. Used the OE pump and mounted the cooler behind the diff.
timd38 (06-17-2016)
