Over Heating!!!!!
Like previously stated, start with the small stuff. Make sure your connection is good. Flush that AF out and throw in some distilled water with water wetter. That will get you off to a good start. I would also hit up your tuner and ask about the fan. Maybe they can adjust further to help?
Aha there's an inter cooler in front of the radiator I missed that!
This is not going to be popular and for the must part will read stupid but if you want to really know how happy is your cooling system with out the inter cooler remove it and replace with equal diameter tubing just for the test.
In your case a dual core alum radiator and dual Spal fans will help a lot.
KM177122 (06-26-2016)
Thanks! Already got the Dewitts but need to upgrade the fans and then go from there. Although, I don't have much in the way of cooling problems. Figured I'd ask since we are on the subject.
Just make sure you get decent fans. Too many people fall for ones that look pretty that actually work worse than stock. Not everything aftermarket is an upgrade over factor.
Also, what hood do you recommend? Thank you!
Received 1,194 Likes
St. Jude Donor '15
D3pe
KM177122 (06-27-2016)
St. Jude Donor '15
You asked... and lots of cars have had overheating problems for years too
Not saying they won't work for your setup.. maybe they will work just fine. But if you want something that will connect to factory computer that will move the most air possible, D3PE's are it
Stay stock, or dual the d3. Only other option is the 17" PWM fan but that doesn't work yet with OEM control, and doesn't flow as much as the d3, and is still ~$700.
I'm not the OP.
#33
St. Jude Donor '15
Details, details
#34
is it just running hot driving around at slow speeds? How is it when driving 55mph and up? Fans don't even run at hwy speeds so if it's getting hot at hwy speeds I would be looking elsewhere other than the fans
#35
I have the dual fans and a Dewitts radiator and live in probably one of the worst possible places to drive a vette....TEXAS! Yesterday it was 104 degrees outside,today its soppose to be 107 degrees!!! Especially in traffic is really when the car will get hot. Im about to get my Setrab oil Cooler because i'm sick of the oil temps going thru the roof.
Quick question, what do you guys consider "normal temp" for a LS3 car Manual 6-speed? That being OIL and COOLANT? just curious to see what your guys temps get up to just to compare...
#36
100-110F over ambient with AC on. 90-100F with AC off.
