Installing sway bars and shocks(maybe) this weekend.
Old 07-20-2016, 09:39 PM
Gene Culley
Premium Supporting Vendor
Gene Culley's Avatar
Originally Posted by GFaulk
The sway bars and shocks have been installed. I had the shocks installed by a local shop. I am thrilled with the result! The shocks are slightly more firm, but not bone jarring. Combined with the sway bars, the car handles much more to my liking. Thanks to all for the suggestions and support.
Awesome. That's the way it is supposed to work. Thank you for your business!
__________________
Phone: 484-334-8833
Owner of CULTRAG Performance
Shop Our Factory GM Parts Website
Old 07-22-2016, 04:24 PM
Gunbearer
Gunbearer's Avatar
Ive got a set of Z51 bars from Cultrag sitting in my garage waiting ot be installed. just have to find the time.
Old 07-23-2016, 02:01 PM
krazy1
krazy1's Avatar
If you are going to the trouble to change the bars & shocks, I would suggest you replace the stock end links with heim joints. It will make a big difference.
Old 07-25-2016, 06:02 AM
MLRS
MLRS's Avatar
I"ve read in the forum that when changing sway bars front or rear the car suspension has to be pre load like on wood blocks or ramps, but I"ve seen some forum members that has done it just taking the wheels off and the vette on jacks support. Asking because I'll be doing mine and want to be sure. Thanks for your info and like always proud to be member of the forum.
Old 07-27-2016, 11:10 AM
Jack Boelte
Jack Boelte's Avatar
I just changed my shocks and sway bars. Bought a tool made by Lisle (LIS20400) that made working with the top nut on the front strut very easy to remove and install. The sway bars were super easy, I made sure to orient them like the old sway bars before removing the old sway bars.
I did run into a problem. The right rear lower bolt seized to the bushing. I ended up damaging the bushing and bolt getting it out. I'm having a really tough time finding a replacement bushing. I hope I don't have to buy a new control arm...
Old 07-28-2016, 03:43 AM
torquetube
torquetube's Avatar
Lift the car by whatever method you like, remove the wheel, and use a separate bottle jack to raise the suspension until the end link is unloaded.
If the link on the other side is disconnected, this isn't necessary of course.
The following 2 users liked this post by torquetube:
ClashBandicoot (08-11-2016), MLRS (07-28-2016)
Quick Reply: Installing sway bars and shocks(maybe) this weekend.
