Fuel Injectors Size LS3
Hi guys! I recently bought an Edelbrock Supercharger with 3.500'' pulley. I should be around 18 psi and 900 RWHP but I'm not sure if I should go with 72 lbs/hr or higher on my LS3. My compression is at 9.4, all internals are forged, better springs, valves and valve seats, 102 mm throttle body, 3'' exhaust line and a high-performance fuel pump.
Either way I would go bigger injectors. 850s at least.
Also this would be better answered in the forced induction section.
Received 1,194 Likes
St. Jude Donor '15
Edelbrock isn't the setup for 900+rwhp
Throw some ID850's or ID1000's in it.
