Clutch is getting stiff when the car is hot.
Tried searching without much success...hopefully I'm not repeating topics.
It's summer now, this is my 3rd summer with my 08 w/z51 and I just recently noticed that when the car gets hot my clutch pedal gets a lot stiffer. This is most noticeable when in stop and go traffic. Engagement feels different when the pedal is stiff...it sort of studders instead of smoothly engaging. I ranger the fluid regularly and it hasn't looked overly nasty as of late. Once the car cools off the pedal pressure/engagement feels normal again.
Anyone else experiencing this?
Mine has been doing this lately as well. No idea what is exactly happening, but I guess 105+ temps will do that sometimes. Once I get moving and get some airflow, it goes away.
Today wasn't too bad. Temps were down in the 70's and no traffic, so the clutch didn't seem to get stiff. I think I'm going to try wrapping the tube from the master to slave as it sits over the exhaust. See if that helps any.
Thanks for the reply Dubs. I guess I feel slightly better that this isn't happening to me only.
I am having this exact issue with my clutch. Cold starts my clutch goes down and back smooth once the car warms up the clutch begins to feel like a resistance when I push in and release. I guess a spongy feeling? I have tried removing the clutch spring and it is doing the same thing.
The clutch fluid is clear. My 2008 base has about 55k miles on it.
I would do this. My clutch line and remote bleeder are in one of those silver heat resistant sleeves with velcro closure. It's maybe the new LS7 clutch and slave but my clutch is always smooth and fairly light all through the summer much more than it was before.
Everyone with this issue has headers, right? Mine started doing the same thing after I installed headers. The stiffness goes away if you pump the clutch a few times in neutral.
Same problem here on my 08' base, with exactly the same symptoms. My car is bone stock too.
Fluid in the tank is clear and clean, but it's not an insurance that the fluid that's in the lower part of the circuit (lower line and slave) is too. I will completely bleed the clutch from under the car this weekend and see how it goes. This morning I inspected the heat insulation sleeve of the upper line (part that's close to the header) and it's not in great shape, maybe that's also a reason. I will look for a replacement insulation sleeve too.
