First Drag Setup. Help me choose tires!
My 08 z06 currently has a 20" 360 forged wheel setup on it with 345 nittos. Not super happy with the nittos and the tires have to be super warm to have a chance of hooking in second. Won't even bother going to the track with them. Looking to pick up a drag setup and I think i've decided on 17x10" rears and 17x4.5 dark stars. I will likely run a M&H front runner, but am lost on the rears. Car makes ~600rwhp. 26" slick? 28" slick? Drag radial? Need some advice here boys!
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19-'20-'21-'22-'23-'24
Put a 325/45/17 M&H drag radial on and call it a day. Proven over and over one of the best DR's available. Going to run the Quick 30 this Saturday night at Royal Purple with that same tire.
I would appreciate feedback from the Fourm,
Thanks in advance.
BIGMAC
I would like to run this tire but there are many reports that it's diameter (listed as 28" but I am told the actual measure when mounted is less) is out of the front/rear diameter difference tolerance allowed by the TC/AH system. The reports say this could cause unwanted application of AH and/or putting the car in limp mode. I have been unsuccessful in determining exactly what the tolerance is. Some say the magic ratio is 1.04 rear/front but the Nitto NT05 345/30/19 on the car now are 1.06 with no problems. I have a heavily modded 2012 GS ready for track testing. I know the Nittos on the car now are useless at the track with 750 RWHP but I don't want to invest in a 17" wheel/tire combo that has a 50/50 chance of causing big TC/AH issues.
Thanks in advance.
BIGMAC
Thanks in advance.
BIGMAC
BIGMAC
Thanks in advance.
BIGMAC
Thanks in advance.
BIGMAC
Like BIGMAC I have a GS with an A6 and the 3.42 Z06 diff, so I need all the tire diameter I can get on the rear.
I'm running M&H Racemasters: 185/55/17 fronts and 325/45/17s on 17x5" and 17x11" Weld RT-S wheels and have had no problems whatsoever with AH activation, which I was very concerned about as well.
FYI: The 185/55s have a measured dia. of ~25.5" and the 325/45s are ~27.5" mounted and inflated to 35psi and 18psi respectively (which my car handles decently with on the street). I'm not sure what the front/rear tolerance ratio is, but these tires work for me.
BTW: I always run my car in "Comp" mode, but I'm not sure if that makes any difference with the AH system?
For a manual trans, you would better be served by bias ply tire rather than a radial. If you can locate a set of MT 26x11.50x17 ET Streets, they would be a great tire. They are no longer made but can produce consistent 1.4s with practice on a decently prepped track.
A bias-ply tire will absorb the initial shock of a manual setup better and so will probably ET better, depending on power output. The only caveat would be, of course, that you will need to run bias-ply front runners with them, otherwise it will get very squirrelly on the top end. Ask me how I know...
Damn that is moving out! What is done to your car? Stock trans and gearing? What'd you have to do to get the 16" wheels to clear the z06 brakes?
Just bolt-ons.
RPS Clutch, 4.10s, CAI, Headers, Ported TB, Ported FAST 102
TR 6060 with stock ratios
Brakes were swapped over to C5Z brakes and knuckles modified slightly to accommodate the 16" Bogarts.
Received 2,061 Likes
http://www.wallaceracing.com/Calculators.htm
IIRC a stock geared Z06 with 315's will run out of RPM in 3rd shortly after the 1000' mark. You want to be just short of the rev-limiter at the stripe, so it takes a taller tire in 3rd or a different rear gear to use 4th.
If you're not too far from the track or you change wheels at the track, the M&H bias skinny is the lighter tire to use. Since the main reason to run skinnys is to reduce weight, you should consider swapping brakes from the J56 to J9L base brakes and save several more pounds.
