Bad AC compressor?
Bad AC compressor?
Hi everyone,
my ac pressure on the low side read 80 psi and 80 psi on the high side when AC is off and clutch disengage. Both low side and high side pressure goes up to 120 psi when AC on and the clutch is engaged
Is this compressor bad or port expansion valve?
I know it's low on Freon, but wanted to fix the problem before adding more, or do I need proper amount of pressure for the Compressor to work properly?
Thanks in advance.
Thanks in advance.
Hi everyone,
Thanks in advance.
Thanks in advance.
Seen like the pressure is too high on the low pressure port to where it won't take anymore freon out of the can so I stopped filling it. I might have to filled when compressor is off. I'm not sure how much I put in. I'll weight how much is left in 22 ounce can.
Just to be sure is it 1.63 lbs is what it call for? My tag are all faded out and can't read it.
Another question is that I can't seen to locate low side pressure switch. Is there one somewhere? in the cab?
Received 1,193 Likes
St. Jude Donor '15
I don't recall ever seeing a low side pressure sensor--only high side. Computer controls the AC compressor
If you have that much in it it's either overfilled or the compressor is just shot. Probably both.
I may try to add some more freon and see what happen at least its less hassle in case it work than replacing the compressor. The pressure should had gone down sitting over night.
What I don't understand is that why the pressure goes up on both side if the compressor is working? I was thinking the expansion valve stuck open but that should it still see different in pressure? if compressor still good? I don't know it's confusing how this thing work.
Thanks for yours input.
Is this wrong freon? or Am I missing something here? Please let me know before I try to fill up some more.
Thanks,
Thanks for the link HK770. Lots of good information
According to the article and everyone else keep telling me on here, the compressor is done.
Quote from links above:
"If we hook the gauges up and see 80 psi on the low side, and 80 psi on the high side, and the compressor hub is spinning, it's likely that compressor is done."
But to my issue why when the compressor kick on it changes pressure from 80 psi to 120 on both hi and low side if the expansion valve does not stuck open? Is it because compressor stirred up liquid freon into gas, but didn't have ability to compressed? That's only explanation I can think of. hmmmm??
Here I go tearing of the supercharger just to replace the compressor. Maybe taking off the exhaust manifold route would be easier and less craps to take apart.
St. Jude Donor '15
I was thinking the compressor spinning might be heating things up and increasing pressure.. but that's the best guess I've got.
I removed the head unit and was able to get the AC compressor out the front that way.. it's a tight fit and takes some yanking, but it will come out that way
If there is a problem or a leak, fix it the right way or risk spending a ton of money to flush it out and replace a lot of parts before using that stuff. Some here will say that stuff is great, I'm not one of them. Unfortunately, the stores put that stuff right up front and center for everyone to see. Look for virgin R134A if you can, it's usually hidden away on the bottom shelf of Walmart or the auto parts store. I'd hate to see you cause more problems than is already there by introducing that stuff into your system.
"Google AC sealant and orifice tubes" and see what you get.... Here's a sample:
https://traxxas.com/forums/showthrea...ar-s-AC-system
Check out iATN in the A/C section. Any of the other techs or shop owners will say the same thing without question.
HK770 sent you a link I was going to post that's good, here is another that's OK with a good symptom chart:
http://www.instructables.com/id/How-...Automotive-AC/
Another with 4 parts to it, also good:
http://www.agcoauto.com/content/news/p2_articleid/256
Gering (08-02-2016)
Usually putting that stuff in there is like putting glue into the system. A lot of shops won't touch your car if they know that is in there (including me). It can plug up the expensive filters on the A/C machines.
Should I do a full vacuum again and refilled with the right stuff or just cross fingers and hope it will be okay? If that would help.
I don't think i have any leaks from what I can tell. I vacuum tested to be good. Anyway I just got it working by adding some more freon. I don't know if it fix itself or fooling with me, but hey it's blowing cold air for now. I end up 9 oz left in the 22 oz can =~ 13 oz in the system. It may need more but i'm not sure exactly how much to put in since my tags all faded out and can't read the freon capacity info. I keep it there for now unless someone here tell me how much of freon is needed or until stop blowing cold air.
on idle pressure read:
high ~250 psi
low ~ 40 psi
at 1500 rpm:
high ~290 psi
low side went down to ~30 psi
~95 to 100 degree ambient, a little low according to the chart but will do for now.
russ474 was right, to you
yes, have the proper amount put in. Low pressure should be dropping and high side should be rising when the clutch is engaged. You won't really know what you are working with until you are running the right amount of freon in the system
Thanks everyone for the help...
Thank you,
so i'm a few oz short.
why didn't I run into this "not to use" sealant freon can's deal. Been searching up and down all over the forum and google the web the whole weeks. And why they are allow to sell them everywhere if it's that bad. Ruins the whole ac system. and The autoparts guys didn't do too much help either.
Well it is what it is... have to deal with it. whose to blame but myself.
Thank you again everyone
Thank you,
The parts guys are just trying to sell product. There's a reason you won't find 30 lb tanks of refrigerant with sealer in them, the professionals don't use it.
On the bright side, maybe that sealer could have 'fixed' a leaking expansion valve which was a symptom of high suction side pressure & low discharge side pressures. Hopefully it will continue to work for you and make cold air.
If you want to further your education, google: A/C compressor black death.....that's another nightmare.
