Motul/Redline/Castrol Fluids
Former Vendor
St. Jude Donor '13
Motul Oils
MOTUL 300 V 0W20 CHRONO 2-LITER
http://www.xplosiveperformance.com/M...r-_p_4110.html
MOTUL 300 V 10W40 CHRONO 2-LITER
http://www.xplosiveperformance.com/M...er_p_2642.html
MOTUL 300 V 0W15 CHRONO 2-LITER
http://www.xplosiveperformance.com/M...r-_p_4112.html
MOTUL 300 V 0W40 CHRONO 2-LITER
http://www.xplosiveperformance.com/M...r-_p_4111.html
MOTUL 300 V POWER 5W40 2-LITER
http://www.xplosiveperformance.com/M...er_p_2646.html
MOTUL 300 V 5W30 POWER RACING 2-LITER
http://www.xplosiveperformance.com/M...er_p_2645.html
MOTUL 300 V 15W50 COMPETITION 2-LITER
http://www.xplosiveperformance.com/M...er_p_2643.html
MOTUL 300 V 0W20 HIGH RPM 2-LITER
http://www.xplosiveperformance.com/M...er_p_2641.html
MOTUL 300 V 20W60 "LE MANS" 2-LITER
http://www.xplosiveperformance.com/M...er_p_2644.html
Motul Brake Fluid
MOTUL RBF600
http://www.xplosiveperformance.com/M...00-_p_648.html
MotulRBF660
http://www.xplosiveperformance.com/M...T4_p_2403.html
CASTROL SRF RACING BRAKE FLUID
http://www.xplosiveperformance.com/C...id_p_4091.html
Redline Fluids
RED LINE’S SYNTHETIC ENGINE OILS 10WT (0W10) RACE OIL
http://www.xplosiveperformance.com/R...Oil_p_921.html
RED LINE’S SYNTHETIC ENGINE OILS 20WT (5W20) RACE OIL
http://www.xplosiveperformance.com/R...il-_p_922.html
RED LINE’S SYNTHETIC ENGINE OILS 40WT (15W40) RACE OIL
http://www.xplosiveperformance.com/R...l--_p_924.html
RED LINE’S SYNTHETIC ENGINE OILS 50WT (15W50) RACE OIL
http://www.xplosiveperformance.com/R...l--_p_925.html
RED LINE’S SYNTHETIC ENGINE OILS 30WT (10W30) RACE OIL
http://www.xplosiveperformance.com/R...il-_p_923.html
RED LINE’S SYNTHETIC ENGINE OILS 5W30
http://www.xplosiveperformance.com/R...W30_p_918.html
RED LINES SYNTHETIC ENGINE OILS 10W30
http://www.xplosiveperformance.com/R...W30_p_913.html
RED LINE’S SYNTHETIC ENGINE OILS 10W40
http://www.xplosiveperformance.com/R...W40_p_914.html
RED LINE’S SYNTHETIC ENGINE OILS 15W50
http://www.xplosiveperformance.com/R...W50_p_915.html
RED LINE’S SYNTHETIC MANUAL TRANSMISSION LUBRICANTS MTL 70W80 GL-4
http://www.xplosiveperformance.com/R...4--_p_932.html
RED LINE’S SYNTHETIC GEAR OIL 75W90
http://www.xplosiveperformance.com/R...W90_p_926.html
Motul Oils
Motul Brake Fluid
MOTUL RBF600
MotulRBF660
Redline Fluids
Former Vendor
St. Jude Donor '13
http://www.xplosiveperformance.com/R...uid_p_934.html
Redline D4ATF can also be used in the power steering system in the Corvette same price and in Stock
http://www.xplosiveperformance.com/R...TF-_p_935.html
Former Vendor
St. Jude Donor '13
Motul Oils
Motul Brake Fluid
MOTUL RBF600
MotulRBF660
Redline Fluids
Motul Oils
Motul Brake Fluid
MOTUL RBF600
MotulRBF660
Redline Fluids
Former Vendor
St. Jude Donor '13
MOTUL
Pioneers in synthetic lubricants, Motul has developed the300V Motorsport range based on the unique ESTER Core® technology that gives youunrivaled power increase, outstanding lubrication and optimal protection foryour vehicle, creating the perfect conditions for ultimate victory!
ESTER CORE® TECHNOLOGY
Over several decades, Motul has perfectly mastered thetechnology of esters. Combining this technology with an optimal selection ofhigh performance synthetic base oils, coupled with an innovative additivespackage, gives exceptional synergy. This is the latest Motul technologicalevolution: ESTER Core. Used exclusively in the 300V range, this technologyguarantees to obtain maximal performance, over and beyond existing standards.
GUARANTEES YOU MORE:
POWER - Reduced internal friction
RELIABILITY - High temperature resistance and oil pressurestability
PROTECTION - Optimized polarity for maximal adherence of theoil film
LOW LUBRICANT CONSUMPTION - Exclusive formulation of lowvolatility synthetic base oils
During the ‘dyno test’ 300V Trophy 0W40 showed significantpower increases up to 7.2 HP compared to competitors
Former Vendor
St. Jude Donor '13
MOTUL
Former Vendor
St. Jude Donor '13
Motul Oils
Motul Brake Fluid
MOTUL RBF600
MotulRBF660
Redline Fluids
Motul Oils
Motul Brake Fluid
MOTUL RBF600
MotulRBF660
Redline Fluids
