Budget LS2 build
#41
You may want to turn the motor over by hand again sometime. I think it would be worthwhile to shorten a socket as much as possible, weld a flat bar onto it for a handle and have a dedicated tool.
#46
Procycle, I am going to cut down a socket that's for sure. The ARP crank bolt is a big boy 1 1/16th 12 point.
#47
Received 1,194 Likes
St. Jude Donor '15
I have also used a crow foot socket on them before, it's slow going but works in a pinch. Not sure how well it would work with an arp bolt though.
With the right size extension you can get it on the crank bolt just barely.
Brandon619 (08-14-2016)
#48
I was doing some research last night and I found a post from Randy@DRM. Randy said he uses the alternator to turn the motor with a bit more tension on the belt. Anyways, moving forward on my build. I finally got my measurements for my pushrods and ordered them through Mamo Performance. Tony was alot of help during this entire process, thank you Tony!
#49
St. Jude Donor '15
Looks nice. May do the same to my valve covers soon
#51
