Fresh Dyno Pull!! *551 RWHP* H/C C6
Old 08-22-2016, 11:27 AM
jbsblownc5
Support Corvetteforum!
jbsblownc5's Avatar
2017 C5 of the Year Finalist
St. Jude Donor '08
Originally Posted by LEAVINU
Why the Z06 torq tube and driveshaft?
I cracked my Tq tube housing, and found a complete Z06 Assembly with only 5K miles on it...
I actually think the 08 Z and Z51 might have the same shaft anyway.
Originally Posted by jesse82nc
So you are all motor as well? That's impressive then!
Yes, NA.
Originally Posted by Suns_PSD
Really crazy high numbers for these mods. The bottom endm torque tube, and clutch should have no effect on the power.
I guess it's all in the cam, the ported FAST, and the NW 102. Wish I had those kind of numbers.
I always run Torco in every tank, as well as Meth injection, and with the forged bottom end and angle milled heads/12:1 comp, I need to run the higher octane, which in turn gives me some nice power!
HC Mechanic (08-22-2016)
Old 08-22-2016, 01:32 PM
Suns_PSD
Suns_PSD's Avatar
I have a bit bumped compression as well but I don't remember the amount. When I run e-85, which should provide me with the same advantages that you gain with your Torco and Meth, I dyno about 505 rwhp (the shop that tuned the car lost the file and could never tell me for certain).
You're car dynos 46 more rwhp than mine but I get that dynos have some variance. Still what I notice from your pull is that your car pulls really hard up top where mine flattens out a lot. My car dries like a stocker at 1000 rpm in 6th gear though.
I also have a baby cam (219/227). It was already in the car so it was hard to justify the cost of a swap for what might not have been much more power.
Since my dyno I have added a Corsa sport which Corsa claims adds about 7-9 rwhp over NPP. And if the new Vararam manifold does anything like they claim it will, I should end up around 525 rwhp when running the E-85. Once the Vararam is available for purchase we'll find out!
I don't feel the 102 does anything really.
Old 08-22-2016, 03:07 PM
HC Mechanic
HC Mechanic's Avatar
Looks like she’s running really well Joel, NICE work!!
Actually very comparable to my LS2 stroker, would be fun to see them both run on the same dyno. Still have to figure out exactly what’s going on with LEAVINU’s monster!!
Old 08-23-2016, 11:19 AM
jbsblownc5
jbsblownc5's Avatar
St. Jude Donor '08
It sure is, thank you Robert...
Old 08-23-2016, 01:20 PM
Mattie Num Nums
Mattie Num Nums's Avatar
Why not use E8X instead of the Torco mix? Is it not available? Great numbers! I am looking to do bolt ons with E8X.
Old 08-24-2016, 10:48 AM
madmatt9471
madmatt9471's Avatar
Location: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Joel,
As always buddy nice numbers, video and combo on the Vette!
Thanks,Matt
Old 08-24-2016, 01:37 PM
lebvette
lebvette's Avatar
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21
Great numbers.
Old 08-24-2016, 09:07 PM
jbsblownc5
jbsblownc5's Avatar
St. Jude Donor '08
Thanks, I have not changed my fuel system to accept E85, and Torco is READILY avaliable to me, as is the Meth. the combo of the two, is pretty powerful when it comes to stopping KR...
Originally Posted by madmatt9471
Joel,
Thanks,Matt
Thank you Matt!!
Originally Posted by lebvette
Great numbers.
Quick Reply: Fresh Dyno Pull!! *551 RWHP* H/C C6
