wheres my LS3 head guys
ok fellas im wanting some input on what way to go with heads . from those of you that have did it on a LS3. im wanting a little bump on compression and to get them ported ect.. What heads did you go with and would you do it again? Car does not have a cam in as of now just trying to get all of my ducks in a row before winter comes and the fun starts to happen .. thanks in advance .
Hello, getting all your ducks in a row is a good thing. First thing is what's the budget? Second thing is this a max power build? Is this a daily driver? The reason I ask is because you could literally go 25 different ways on cam shaft select, yes I understand that your asking about heads. As far as heads if you have a unlimited budget go with a set of Trick Flow heads from Tony Mamo do his magic with them. While your at it have him spec you a cam for your power/driving needs. If your limited on a budget have AI port your heads and add some thinner head gaskets and purchase an off the shelf cam and assorted parts. Back to the cam shaft, if your getting all your ducks in a row do it right from the beginning. I speak from recent experience, you will spend more money back save in the end ask me how I know. Good luck on your search.
yeah its a DD and im looking to just looking to bump up the compression a little and get the heads cleaned up but i wasnt sure really if any one was better on these motors than the other ..
arc6, a bump in compression is a simple fix just replace with a thinner head gasket. I would plan out your build so you can utilize labor and tuning cost.
http://www.lingenfelter.com/product/...l#.V8zuH-y42ZM
You'll need a new set of 'better than stock' valve springs and a good tune with a cam like this......should easily gain you in the 50 to 60 hp range.
KW
