ABS/Traction/Service Traction lights
I'll have to look those up in the service manual. I would take the left rear wheel off and have a look around the wheel bearing connector(unplugged, damaged wires). It looks like you might have two separate issues going on but who knows sometimes one code can trigger 5 others.
I will check that out when I get home.. I have a air bag light on as well from when i unplugged the airbag, but it seems no matter how many times i clear the code wont go away =/
yaw rate
you seem to have issues with your yaw rate sensor and wheel speed sensor
The airbag light could come from the yellow plug under the drivers seat if your car has the "easy exit" feature where the seat and wheel move back everytime you open the door.
Nope i dont have the easy exit feature. i knew i should nto have unplugged my air bag that one day lol
So the manual says C0045 is specific to the Left Rear as indicated by the tool. Find links below to the testing procedure. It' most likely a worn wheel bearing if everything looks in-tact visually.
http://stevehaefner.com/dl/Circuittesting1.pdf
http://stevehaefner.com/dl/Circuittesting2.pdf
http://stevehaefner.com/dl/Circuittesting3.pdf
