ABS/Traction/Service Traction lights
So ever since I installed this firebird linelock which uses the summit linelock.. I have beeen having issues, as first the lights would come on randomly, now its everytime i start the car.. Its not throwing a code in a obd2 reader, anyone have any ideas?
I have this issue although mines only at high speeds. Hope you find a answer to it
Unfortunately I think.it can be caused by allot of th I hs I think I need to change out my wheel hubs. A radiator bracket broke and it may have damaged some wiring as I speed up it would set of off it's better now but not gone. Agreed very annoying. I like to have abs lol
Yes.. i do have one that was replaced and they cant get it programmed until i get a new horn installed i guess.. least what discount told me.. can that cause the issue?
so i got the tps set to the car.. abs light and traction control light still come on.. after one stop they were off but when i braked normally just lightly the abs kept coming on ... and now lights back on
damascus1986 (09-26-2016)
Does it pop up as soon as you start the car or as soon as you start moving?
95% of the time right as the car starts.. 1 out of say 15 starts they wont come on.. for electrical i went to the same line i used for switch power inside the car for me gauges...what type of scanner is needed? techII?
You haven't taken the steering shaft loose or wiggled any wires near the steering wheel position sensor?(under dash in-line with the steering column?
A damaged wheel bearing could also cause this(smashes the wheel speed sensor inside it).
Yes a tech 2 will show the code but there are other scanners that will as well. It just needs to be able to read ABS codes.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I spun my steering shaft accidentally one time while it was off and it caused AH/TC warnings because the steering wheel position sensor was seeing the wrong readings.
